Author Subject: Engine rebuild
markylee
Hi all I've just removed my doner engine for my race car. I'm gonna list all the things I'm going to do to it, please add anything I've missed or opinions on what I've listed, all advice appreciated.
Ok the engine is going to have throttle bodies and cams to suit.
Gas flow head
Valves reseated? (Any advice)
Skimmed head
Pocket pistons
Block skimmed
Knife edge crank
Balanced rods crank, lightened flywheel and pulley.
Replacing rings bearings etc.
Like I said earlier this will be my first project so any advice welcomed
Posted 10th Dec 2013 at 21:12
cully
some part numbers that might come in handy
they have been to me as im part way through a rebuild too
XU10J4RS
Head Gasket 45.84 GBP
Peugeot 0209Z2
Head Bolts 7.57 GBP
Peugeot 0204AO UP TO O 08581 REMOVE WASHER 0205 47
Rear Crankshaft Oil Seal 18.74 GBP
Peugeot CRANKSHAFT BEARING SEAL 90X110-7SFCM - 0127 28
Camshaft Oil Seal 11.80 GBP
Peugeot ENGINE CAMSHAFT SEAL DIAM 36X50-7 0236 44
Front Crankshaft Oil Seal 14.34 GBP
Peugeot CRANKSHAFT BEARING SEAL 42X62-7 0326 22
Valve Stem Seals 1.39 GBP
Peugeot ENGINE VALVE STEM SEAL DIAM 12 - H 10 095638
VALVE GUIDE Stem REPAR 0220 96 18.55 GBP
SET OF 2 VALVE SPING 0952 A6 5.54 GBP
Valve collets 0950 20 2.51 GBP
Inlet valve 28.44 GBP
Peugeot 094882
Exhaust valve 37.32 GBP
Peugeot 0949 87
VALVE SPRING RETAINER Top 0951 36 2.40 GBP
VALVE SPRING RETAINER Lower 0953 20 2.56 GBP
Timing Belt Kit 98.98 GBP
Peugeot DISTRIBUTION MOTOR KIT 0831 48 RP 0831 R5
Timing Belt 42.14 GBP
Peugeot TIMING BELT 136 DTS HT=34 0816 98
peugeot TIMING TENSION ROLLER 0829 35 53.33 GBP
Bolt GEAR-BOX HOUSING COLUMN SCREW M8X125(2) LG 16-34 0820 17
Bolt SELF LOCKING SELF-TAP SCREWS DIAM 8X125-25 6923 78
Peugeot RETRACTOR ROLLER 0830 37 RP 0830 63 27.44 GBP
Bolt HEX HEAD CAPSCREW DIAM 10X150-50 6921 C2 RP 6921 91
Hydraulic Cam Follower 27.38 GBP
Peugeot 0942 31
Cam cover screws
SCREW WITH BASE DIAM 6X100-38 0205 51
SOCKET CHEESEHEAD SCREW DIAM 6X100-25 6913 F6 / RP 6913 N8
COOLANT MANIFOLD GASKET DIAM 42 (back of block) 1339 83 1.52 GBP
WATER PUMP GASKET 1206 A4 2.58 GBP
ENGINE WATER THERMOSTAT 83 DEG 1338 39 21.65 GBP
ENGINE WATER THERMOSTAT GASKET DIAM 51X57-4,5 1340 48 1.10 GBP
ENGINE WATER HOUSING-Block SEAL 1340 33 3.48 GBP
ENGINE GASKET KIT 0197 W2 115.87 GBP
GEAR-BOX SEAL 40X58-10 3121 44 RP 16 088 167 80 11.00 GBP
GEAR-BOX SEAL RIGHT29X47-11 3121 46 12.94 GBP
INLET MANIFOL GASKET 0349 G1
THOTTLE BODY SEAL PIECE 1635 C3
EXH MANIFOL GASKET 0349 F4
EXH DOWNPIPE FIXING KIT 1798 75
Posted 10th Dec 2013 at 21:31
markylee
Cheers mate
Posted 10th Dec 2013 at 21:34
pete_rallye
Wouldn't bother knife edging the crank, doubt you'll find anyone to do it anyway but its really not worth it unless you're hitting 9k rpm+ and can actually screw you're engine up. Those big balance weights are there for a reason! Its not usually necessary to skim the block, a good rub down with wet and dry will give you a nice clean surface. Getting the valves reseated is definately a good idea. Find someone with a Serdi machine, it cuts the valves and the seat to the same angle and gives a nice fit between the valves and the seats with no further work.
Lap of the 'ring
Posted 10th Dec 2013 at 22:02
markylee
Cheers Pete do you know anybody with a serdi machine
Posted 11th Dec 2013 at 07:09
pete_rallye
Not near you, no! There's a few places up here that have them, so there's got to be lots of people near you that have them! I'd suggest googling!
Lap of the 'ring
Posted 11th Dec 2013 at 18:51
miles
Should be loads of places around your way, Head work I would just clean up and nothing else as you can end up making things allot worse
Crank, agree with Pete 100%,
For balancing I always use http://vibrationfree.co.uk/
See if you can get some Forged Pistons and Steel Rods, save mucking around with the std ones
But not knowing your history, If starting out then spending the money on time in the seat and training will get more out of you and the car than £10k on the engine and suspension
www.pugracing.com
Posted 11th Dec 2013 at 22:57
markylee
Cheers miles, I'm trying to keep costs down, so forged pistons and steel rods might be a no no. I'm not after massive power gains, hopefully around the 200bhp mark, I'm a reasonably experienced circuit driver( but no Schumacher ). Just need a bit more power for the class I race in.
Posted 12th Dec 2013 at 08:26
craig903
If your changine crings then your may require a rehone aswell.
208 GTI Owner
Posted 12th Dec 2013 at 10:37
markylee
Cheers Craig what is the benefit of a rehone, may sound silly but I need to ask
Posted 13th Dec 2013 at 08:07
Cleans up the bores ready for new rings. Smile
Posted 13th Dec 2013 at 11:54
craig903
Basically what stan has said already but it helps to bed the rings in and to stop the bores from glazing.
208 GTI Owner
Posted 13th Dec 2013 at 13:05
markylee
Cheers lads I'll get it done
Posted 13th Dec 2013 at 21:24
demondriverdan
Bit of a bump, I'm trying to get a replacement set of cam cover bolts:
Can anyone point me to a link for these bolts or generic equivalents? I'm not sure if they're M6 x 100 or what!
Rallye Race Car
Posted 27th May 2015 at 14:44
http://www.ebay.co.uk/itm/PEUGEOT-CITROEN-VARIOUS-MODELS-SOCKET-SCREW-10-PK-NEW-GENUINE-6913N8-/150880174576
just chuck the part number in ebay
probably get them for half the price in stainless at an engineering firm
Posted 27th May 2015 at 15:13
demondriverdan
Cheers! Finding the shorter ones is more of a pain, will probably just order them from Pug
Rallye Race Car
Posted 27th May 2015 at 15:27
you mean the longer ones? the link is for the 25mm ones i think. the 38mm ones are the others. i'd just go to an engineering place honestly, it'll be peanuts
Posted 27th May 2015 at 15:43
demondriverdan
Ok, cheers
Rallye Race Car
Posted 27th May 2015 at 18:12
