Author Subject: 206 2.0 HDI Coolant Replacement
bennn
Mate hit a fence post in his 206 at the weekend.
We've had to replace the rad, AC rad and fans.
I put it all back together last night, but haven't yet put any coolant in.
Is it just a case of filling it up and setting off or do I have to bleed the cooling system.
Any pointers would be appreciated as I've never changed coolant myself before.
Cherry Red 306 HDI
Posted 4th Dec 2013 at 13:36
unless you've just topped it up you'll be needing to bleed it
it's just a case of either flushing it through (i wouldn't bother) or just refilling it and bleeding from the bleed points
Posted 4th Dec 2013 at 13:49
bennn
OK, so I'll fill it then bleed it.
Does anyone know where the bleed points are? Is it just a case of open them all, fill the system until water comes out of them then shut them one by one?
Cherry Red 306 HDI
Posted 4th Dec 2013 at 13:56
i imagine matrix pipes, thermostat housing, radiator - similar to 306 (back of engine, middle, front)
edit> is it the same dw10 engine used in the 306 hdi?
Posted 4th Dec 2013 at 13:59
bennn
Think its the same engine as my HDI yeah.
The expansion tank is located at the back of the engine bay though so I assumed the cooling system is slightly different.
Think I've got the jist of it though. Thumbs up
Cherry Red 306 HDI
Posted 4th Dec 2013 at 14:22
honestly3k
What rikky says is true. Same bleed points as a gti6, start at the Heater Matrix, then work back to front of the car.
Same as my xsara HDi also Smile
Posted 4th Dec 2013 at 14:45
bennn
Thanks.
From what I've found online there are four bleed screws, all on the heater matrix inlet pipe.
I didn't see any bleed screws on the radiator either when I put it in.
Don't think I'll need to make a header tank either, as the expansion tank is higher than all of the pipes at the back of the bay.
Cherry Red 306 HDI
Posted 4th Dec 2013 at 15:04
eh? four? like a valve block?
Posted 4th Dec 2013 at 15:17
No - like a flute.
  • Posted 4th Dec 2013 at 15:22
    i'll show you my flute
    Posted 4th Dec 2013 at 15:23
    bennn
    Yep a valve block.
    Cherry Red 306 HDI
    Posted 4th Dec 2013 at 15:29
