Author Subject: Thermostat housing help?
Pug bazza
Hello guys, I need to replace the thermostat housing as it's been cracked and it is dripping small amount of coolant, my questions are ( A.) shal I use a heat sealant when putting the new thermostat housing in ? ( B.) do I have to re-bleed the system once I replaced it ? (c.) would a cracked thermostat housing mean air could get in to the coolant system, and also I know it's only small amount but I got a connection on the gearbox directly under the thermostat housing and I think it's dripping I the wire so could I hear the consequences if the coolant drops on the connection ( just something i want to bare in mind) thanks guys as usual all comments and help appriciated
Posted 28th Nov 2013 at 20:32
A - No, just use the correct gaskets from Peugeot.
B - Yes.
C - Yes.
Posted 28th Nov 2013 at 20:34
Marcdimma
Easy too replace even tho I broke 2 housings Cos I didn't put thermostat rubber on properly bought my third of ere for £7
Posted 28th Nov 2013 at 20:51
Pug bazza
Thanks guys I seen some in eBay but I think I rather get omp, thanks guys again
Posted 28th Nov 2013 at 23:26
Pug bazza
Mind you if the part number is the same will the eBay one be ok to lol see goin back on my words,bad bad boy
Posted 28th Nov 2013 at 23:27
Just buy the correct part from Pug, they're not overly expensive. Smile
Posted 29th Nov 2013 at 06:03
jeffers Forum Admin
^^ This, they're about £17 iirc.....
Team Running Engine again!
Team Negative Camber!
Posted 29th Nov 2013 at 07:35
