Author Subject: crank pulley - recommendations?
6speedmanual
Preparing to do my cam belt and want to heve a pulley on standby so I can do the job in one go.
Anyone used one of these?
http://www.ebay.co.uk/itm/PEUGEOT-306-HATCHBACK-2-0-S16-120KW-97-00-CRANKSHAFT-CRANK-PULLEY-/251091543563?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3A306|Cars+Type%3A2.0&hash=item3a7638e60b
Or what do you recommend and from where do you source it?
Thanks
Peter
Posted 18th Nov 2013 at 22:15
Get a solid one from richw or spoox cost a lot less than £130
Posted 18th Nov 2013 at 22:26
Rich E Forum Admin
Check the condition of your current pulley. There may be no need for you to get a new one at all.
Time up the pulley and then check the cam timing. If the cams are correctly located then your existing pulley is fine.
Posted 18th Nov 2013 at 22:50
Niall
Or the original pug pullies had marking arrows which should line up so you can see if they have slipped or not.
Posted 18th Nov 2013 at 23:55
jord294
I have a brand new genuine Peugeot one I may consider selling.
I know I should state a price, but need to check retail on it first Wink
Posted 19th Nov 2013 at 01:06
6speedmanual
Hi Jord
I'd be interested in that. Can you. tell me the part no? Priv mail me if you would like to negotiate off line.
Niall
Useful tip. I shall take a look.
Good point but I want to hit the job in one go hence part on standby.
Cheers all
Peter
Posted 19th Nov 2013 at 02:43
jord294
0515.k6 and just shy of £110.
i think the best i could do including delivery, would be £90
Posted 19th Nov 2013 at 06:37
The best option is to buy a solid pulley from Rich_W. Yes
That way, you get the advantage of a lighter rotating mass on the crankshaft and the pulley can't slip, so you can use it for every cambelt change knowing it's correctly timed.
Posted 19th Nov 2013 at 08:16
rich306
This is my next move whilst the car is stripped down lol Razz
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 19th Nov 2013 at 08:26
