Red Rallye - Rolling "restoration"Wishbone Polybushes available
| Author | Subject: Captive nuts - Subframe |
daver6
Seasoned Pro Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
Right, so my captive nuts have quite a bit of play on them and it's causing it to knock as the joint gets moved about (braking, hard turn-ins etc). I've not had a chance to look for a solution, but as my car isn't with me, does anyone know if the nuts can be repaired in the subframe, or is it a new subframe I'll need?________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
Rich E
Which captive nuts? If you mean the ones on the front wishbone mount point that the long bolt screws into then they're supposed to be loose.________________________________________ Rich |
daver6
Even when tightened up?________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
They should go solid once done up, it seems to me that your bolts are either going thread bound (not sure how) or your just not doing them up enough, you can just slide the nuts out of the subframe! |
daver6
I had a quick look and the bolts are thread bound or stripped. They bind up whilst being undone and have play when tightened. If the nuts will come out of the subframe, like you say, I'll just windy gun it out and make another nut________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
stan_306gti6
You can buy the nuts for a couple of quid from Pug. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
daver6
ah cool, I thought I might have had mid-engine-swap hassle there ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
pugheaven
I think iv got some bolts and nuts in one of my old subframes if you want you can have them for postage cost |
daver6
Yeah, drop me a PM if you find them! ![]() ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
daver6
Need some nuts. Poogeot say NLA________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
Not according to serviceboxp/n 3522 55 ________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
daver6
Yeah, I saw them too. The parts man read the part number back to me and he later phoned and told me they're NLA________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
try 3522 92.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
you'll need 6925 P7 too, different thread pitch.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
daver6
I've already received the correct bolts now ![]() ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
Then you'll have to suck it up and buy the matching bolts and 'nuts'. I have a couple of the old type of 'nut' somewhere if you have the existing bolts handy. Edit. Notice you stripped the old bolts. I'll have some, but they'll be with a million other similar bolts ________________________________________ ![]() |
daver6
I've got the old bolts but need the nut. Please ![]() ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
