Author Subject: Cam belt noise
heliosphan
What's this?
That noise is coming from the cam belt area and increases with revs.
Impending doom?
Posted 16th Nov 2013 at 11:15
That sounds like a tapper already, is it? Dunno
Posted 16th Nov 2013 at 11:59
heliosphan
No, never was. It's never snapped a belt or had the head removed. Last belt change was in 2009, this is the first time it's made this noise.
Can a tapper just suddenly 'happen'?
Posted 16th Nov 2013 at 12:12
jeffers Forum Admin
Only if a hydraulic lifter was to fail but to be fair I've never heard of it happening....
Team Running Engine again!
Team Negative Camber!
Posted 16th Nov 2013 at 12:13
heliosphan
Would this theory carry more weight if I were to tell you that the car has been off the road since July 2012 and only gets started to idle/3 point turn in the driveway once every few weeks?
Lifter sticky/not filled with oil? (No idea what I just said but it sounds like some words to use)
Posted 16th Nov 2013 at 12:19
Yep, it certainly would. Yes
Lifters can get stuck if they are not used regularly or had time to get up to temperature etc.
Take it for a 15 minute drive and use some revs - once up to temp and see what she sounds like after that. Smile
Posted 16th Nov 2013 at 13:03
daver6
Had this once when I started up one day, out of the blue. My oil level light wasn't flashing and it said there was oil... but obviously not quite enough, I topped it back up and after a minute the noise was gone
Wishbone Polybushes available
Posted 16th Nov 2013 at 13:08
aaron6
My lifters get noisey when its due an oil change. Sounds like a tapper for the 1 minute or so. Its always done it and always goes away. Smile
Posted 16th Nov 2013 at 14:29
heliosphan
Thought I'd update this as I finally got around to changing the oil and filter today. Took the 10w-40 semi synthetic out and put my normal 5w-40 fully synthetic in. No tapping noise evident after a ~20 minute idle up to temperature (can't drive it on the road obviously) so it was indeed a hydraulic lifter.
Cheers for the suggestions/recommendation of an oil change.
Posted 13th Jun 2014 at 20:43
Glad it turned out well in the end then. Smile
Posted 14th Jun 2014 at 00:26
honestly3k
Sounds like she's crying out for a good ragging Smile
Posted 14th Jun 2014 at 00:49
heliosphan
One final update for this, years later. LOL
The oil change in 2014 stopped the noise for some time but eventually it did creep back in after about another year. By this time I knew it was a hydraulic lifter, not a bent valve, so didn't worry about it. My intention was to wait until I got the car back on the road again in order to put the engine under load and rev it a little more.
Two weeks ago I finally got an MOT test and put the car back on the road. The hydraulic lifter is now completely silent at all times: cold, warm, long idling etc.
Hopefully this saves someone in future from taking the head off, under similar circumstances.
Posted 23rd Apr 2016 at 10:52
Yep, lazy lifter from not being used.
Posted 25th Apr 2016 at 23:24
SmartyC
A useful post, for relatively new owners like me, cheers.
Smarty
My lil toy:
http://www.flickr.com/photos/martincurtisphotography/sets/72157640014140786/
Posted 2nd May 2016 at 12:57
