Author Subject: A long shot but.. rs500 rad + cooler
pugheaven
Has anyone ever used/ fitted an rs500 rad and/or intercooler? I haven't done any measuring yet but think this setup may be the way forward with the dimma to avoid the boost pipes going under the cross member Dunno
I would still have the boost pipes at the bottom and have the rad on top of them (with some clearance)
Iv never owned a car that uses a header tank so not sure how they are plumbed in but I can assume that you can either have a t-piece off one of the pipes going into the rad or a separate pipe that goes into the rad Dunno
Posted 15th Nov 2013 at 22:10
Depends on core size I'd say ?
I'm not a fan of running the boost pipes under the front ? Could you not have side mounts and come round the side ?
Posted 15th Nov 2013 at 21:46
pugheaven
The boost pipes wouldn't be under the cross member just under the rad instead of using the intercooler as intended and having the boost pipes on top!
I could go round the sides but im not sure as too how much clearance I will have with the wheels
Posted 15th Nov 2013 at 21:49
I mean the side of the rad dude not the whole front end
Posted 15th Nov 2013 at 21:51
pugheaven
It would have to be a very narrow intercooler and I would still need to get a different rad ill post up a picture of the rs500 set up so you get an idea
Posted 15th Nov 2013 at 21:53
pugheaven
but with the intercooler so that the boost pipes are at the bottom rather than on top
Posted 15th Nov 2013 at 21:57
What's the core size ? You need maximum cooling as boost = hot Yes don't want a melt down
May need a custom rad with large core ?
Posted 15th Nov 2013 at 22:01
pugheaven
I know that's why I want to change from the current set up, if its good enough for a cosworth im sure it would be fine for me
Posted 15th Nov 2013 at 22:06
I'm sure if they cool the air from massive power cosworths they will cool the sc boost okThumbs up
Posted 15th Nov 2013 at 22:07
pugheaven
question is how do you plumb in a header tank as iv never seen how they are set up or had one before
Posted 15th Nov 2013 at 22:09
Try here: http://www.locostbuilders.co.uk/viewthread.php?tid=77967 for information, a useful thread. Yes
Posted 15th Nov 2013 at 22:18
pugheaven
that's random I had just found an image from the same website on google
Still confused lol so I would need an expansion tank and a header tank?
Posted 15th Nov 2013 at 22:32
superchargedblack1997gti6
the only thing I'd say about that Ollie is the core on the intercooler on Richws old car is significantly bigger by 60mm.?
I think that the design of the intercooler and rad is spot on and it will work been tempted to do it myself you'll be fine it'll definitley cool the car enough. just wonder because you won't have as much intercooler exposed with this design.
Posted 16th Nov 2013 at 07:39
pugheaven
From speaking to nick I have the largest intercooler out of everyone and is maybe s bit over kill
I'm going to do some measuring today and see if it will fit!
Work have mentioned about me going back out to the sand pit again in Feb so I really need to crack on with the dimma if I decide to go
Posted 16th Nov 2013 at 08:45
Let me know if it fits mate as it may safe me a massive wedge if it does!
Posted 16th Nov 2013 at 09:17
I think you only need an expansion tank if your pressure cap is on radiator, on a header tank you just run a pipe down towards the ground like on the standard gti6 radThumbs up
Posted 16th Nov 2013 at 09:57
Basically a header tank wants to be the highest point in cooling system, with two pipes atleast to so you get coolant flow through the tank.
One off bottom of tank T pieced into a pipe to feed out of header tank,with my 309 I converted to gti6 eng I put it into the pipe that runs from thermo housing to rear of block by water pump, then pipe going into top of header tank to return coolant.
Posted 16th Nov 2013 at 10:01
eddy_gti6
Get in touch with birk to see how he has his set up? He runs his intercooler pipes around the chassis legs and sure he hasnt had any issues mate
Posted 16th Nov 2013 at 10:53
Hawkesfire
Hi i had this set up in my Rallycross 206 where the intercooler is in front of the rad and the hoses run round the outside of the front rad crossmember.
Even after fitting a huge brass rad behind the intercooler it would over heat when on high boost due to the intercooler robbing all the cool air and it eventually overheated and picked up a piston when i was leading the final and i took a chance when i knew it was running hot and trashed £1000 of pistons and rods.
I have now moved the rad to the rear of the car so it has maximum cooling without it affecting the intercooler.
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 18th Nov 2013 at 12:30
I think you are a special case though as you must spend an awful lot of time at full revs but not high speed!
Posted 18th Nov 2013 at 13:47
Yeah, we have similar issues with the buggies, they're a bas**rd to keep cool when you're using so much power but low average speeds.
Radiator shrouds and great big fk off fans are the answer Big grin
Posted 18th Nov 2013 at 14:12
