Author Subject: I dont want to jynx it but.....
doon1988
So four things happened yesterday.
1 - Oil and oil filter change.
2 - I got a de-badged bonnet and smoother fiberglass grille.
3 - Fitter a new Temp switch (brown one)
4 - whilst running the car up to temp to see if the fan switch solved my fan/ overheating issues the radiator started spurting coolant from the cap. Took the cap off and the seal had sorta of half disintegrated. Managed to get a new rad cap and drive the car home then to work today.
Now since all that - My car seems to be driving much smoother (still getting hot but seems to be taking a little longer) but the main benefit i am noticing is that when driving and slowing down changing gears for traffic lights/ junctions or traffic. When I dip my clutch previously what used to happened was my rev counter used to drop pretty fast and sometimes drop way below standard idle but then pick back up, other times it just to drop and stall.
Now since the above when I dip my clutch the revs are dropping much slower and tend to remain around idle point.
Oil filter and oil change - never effected this so far so that ones ruled out.
De-badge and grille... Ruled out unless for some reason my car cannot cope with the extra little bit of weight. which I cannot imagine.
Which leaves me with either replacing the temp switch or fitting a better sealed rad cap which is aiding this.
I personally couldn't imagine any of these having said impact because the issue was only when slowing down/ stopping and not at any other point when driving.
Anybody got any thoughts around this. - I haven't touched the ICV yet so cant put that in as a factor.
One thing is for sure though... I much prefer the look of a de-badged bonnet Big grin
Before
After
Posted 11th Nov 2013 at 08:47
Debadged bonnets rule...Yes
I think it makes the car have a much more modern look from the front end. Smile
Posted 11th Nov 2013 at 09:03
doon1988
Its not fully fitted yet i.e. the grille is held on with cable ties as my previously grille was bodged and I am guessing the people misplaced the proper screws and instead drilled some small holes through the grille and in to the slam plate to then use some normal small screws to hold in place.
The guy I got the bonnet of is also selling, a smoothed tail gate. Full leather black and blue seats in near mint condition as well as I few other pieces I am tempted to go back for.
Fortunately for me (unfortunate for him) after buying a shell in April and spending 4k doing it up to take to FCS 2013 his dturbo shot some pistons and he is now breaking.... Very nice car too so hopefully I get get some more extras on mine.
Posted 11th Nov 2013 at 09:07
I think the bonnet badge finishes the front end off nicely personally.
  • Posted 11th Nov 2013 at 09:19
    doon1988
    But what about the idle/ cut out issue? Any guesses on that? Was speaking to a guy at work that reckons it could have maybe been the ECU detecting there was a breach (i.e. the leaky seal) and taking action to shut off the car to prevent further damage.
    Could this be a possibility?
    Posted 11th Nov 2013 at 09:22
    doon1988
    I've personally been wanting to de-badge my bonnet for years but never got around to it. Like you say thought its all down to personal taste.
    Posted 11th Nov 2013 at 09:23
    welcome to team De-Badged! now just sort that bumper out LOL
    Posted 11th Nov 2013 at 09:48
    doon1988
    The guy is selling a bumper for £40 so Im tempted to just go for that rather than messing about patching it and re-spraying.
    Posted 11th Nov 2013 at 10:02
    daver6
    Yep, smoothed/debadged isn't for me totally ruins the front end imo
    Wishbone Polybushes available
    Posted 11th Nov 2013 at 10:07
    eddy_gti6
    I use to like the smooth front end untill I had one and now I prefer the badge up front
    Posted 11th Nov 2013 at 10:31
    Thumbs up
    do that there's an faq on the bumper removal from a lad called Welly if you're not sure how to remove yours Thumbs up
    Posted 11th Nov 2013 at 11:11
    doon1988
    ahhh I jynxed it... Its cut out a good 4 times since Sad
    Posted 15th Nov 2013 at 11:16
    7057sam
    Exactly the same.
    How old your icv, pas sensor, lamba sensor?
    Check engine oil? Thinking you may have a hg failure starting?
    Team rallye,built for track
    Rallye dead Sad
    Secret Team Astor...
    Posted 15th Nov 2013 at 12:06
    doon1988
    hg failure? Oil gets changed regular? ICV, PAS and Lamda.. Ive not changed in the last 4 years ive had the car so maybe originals....
    Posted 15th Nov 2013 at 12:09
    doon1988
    7057sam wrote:
    Exactly the same.
    You mean head gasket? I dont think it would be that to be fair the issue has been happening for quite some time (atleast a year) but ive never had time/ space or money to look in to it until now.
    I get around the issue by when im changing gear quickly release the clutch i.e. dont hold the clutch down too long and take ages to change gear. Or if I want to hold the clutch down then sort or double dip it. i.e. dip it change gear and lift of a little then dip again.
    Doing that I have no issues at all which leads me to thing its more a sensor or ICV issue rather than HG.
    But happy to take some pointers/ be corrected and all that Smile
    Posted 15th Nov 2013 at 12:45
    It will be a sensor issue, not the HG.
    Posted 15th Nov 2013 at 16:01
    honestly3k
    Badged bonnet ftw imo Razz
    Posted 15th Nov 2013 at 16:25
    doon1988
    I've just got an icv and lambda off eBay for 27 quid posted. After that I'll try pas sensor or throttle position switch. few years back I got an advisory for a pas leak somewhere but that's never been picked up since and was about 3 years ago and I ain't losing fluid so Maybe a red herring.
    Posted 15th Nov 2013 at 16:58
    doon1988
    Good New i think - I had my clutch changed over the last week and had a new VSS fitted whilst the box was out as my speedo used to be intermittent.
    Since getting my car back on Friday my speedo has worked all the time and so far no cutouts/ stalling so hopefully that was the cause of the issue..
    Posted 3rd Mar 2014 at 13:18
    pete-gti
    Love smooth bonnet , been after one for ages
    Posted 3rd Mar 2014 at 17:16
    jimmyhackers
    dunno if this has been suggested.......but reset you ecu under a high electrical load.
    this helps counteract/stop your revs dipping below idle when letting off the gass pedal
    Posted 3rd Mar 2014 at 17:41
    VSS issues have in the past been known to cause running/stalling problems. Yes
    Posted 3rd Mar 2014 at 22:39
    doon1988
    Jimmy it looks like the VSS has solved the issue. I dont know but I would guess if the ECU thought it was not moving due to the VSS not working them I am guessing that would be triggering or not triggering as the case may be other re-actions and hence the drop in revs/ stalling.
    But so far Ive had it back a week and half and no cut out issues.
    Posted 10th Mar 2014 at 12:15
    doon1988
    Shame the one I got seems to have been done on the cheap Sad all the paints flaking already so after paying out £100 for that and the fiberglass grille im not probbaly going to have to get it resprayed.
    Posted 10th Mar 2014 at 12:16
    mik
    stan_306gti6 wrote:
    I think it makes the car have a much more modern chav look from the front end. Smile
    I'm not really a fan of de-badged front ends. It looks try-hard IMO and I keep wondering if all the filler is going to fall out.
    Still, each to their own.
    Cherry Rallye SOLD
    Posted 10th Mar 2014 at 18:55
