Author Subject: What are the benefits?
jord294
Hey guys
Never ever used uprated discs an a car, so can someone tell me the advantage of using either straight grooved, curved grooved or x drilled
Thanks in advance Smile
Posted 10th Nov 2013 at 17:08
jimmyhackers
the more funky the pattern, the cooler you look
grooves skim the pad lightly so your meant to have a fresh pad surface whenever you brake (no pad glazing) im guessing straight or angled grooves and and how many determine how much the skim off per rotation is.
holes help disapate heat, however i hear that sometimes when your discs overheat, these holes cause so much of a tempreture difference they cause excess contraction in relation the rest of the disc that sometimes they can cause cracks and fracture the disc.
i figure this bad effect with drilled holes is increased further by a vented disc, as the vents sort of work like little turbines pushing air out the hole and further cooling that localised area.
id go with curved or straight grooved with no holes personaly, if you go with curved grooved make sure you fit them the the correct way round.
keep the vents in em clean once in a while with a long thing wire brush in a drill.
Posted 17th Nov 2013 at 01:05
midlife
Don't bother with Max Power style discs.
Just keep oe discs & spend your money on uprated pads like Ferodo DS2500's
The higher coeficient of friction helps lots
Cool
Team 330™Cool
Team "no front end or engine"
Posted 17th Nov 2013 at 03:32
jord294
Well I've just bought some new rotors with a straight groove now
I was advised not to buy x-drilled, as they have a tendency to crack
Posted 17th Nov 2013 at 07:52
midlife
Doh
Cool
Team 330™Cool
Posted 17th Nov 2013 at 18:09
jord294
I just replaced the old units with exactly the same spec in the end.
I just used a slightly bigger rotor Wink
Posted 17th Nov 2013 at 18:22
jimmyhackers
so my essay was for nothing? Sad
Posted 18th Nov 2013 at 17:48
RetroPug
Std. discs and good pads are more than adequate for road use.
Yes, grooves do very lightly skim the pads to remove any brake glazing, but under road use your pads simply will not get hot enough to glaze over. The glaze is the adhesive component in the pad material melting, rising to the surface and hardening again when it reaches cool air. For this to happen the material of the pad has to be heated up to very large temperatures under prolonged abuse.
You're probably just increasing wear on the pads, at increased cost, with little tangible benefit fitting grooved discs to a road car that doesn't brake hard repeatedly.
Likewise with drilled discs, did your old brake discs melt or warp under extreme heat? If no, then I also see very little point in bothering with them.
By all means if you take the car on track and want to combat the negative effects of the brakes getting too hot then they are worth looking at.
Posted 18th Nov 2013 at 18:16
mattgti6phase2
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 18th Nov 2013 at 18:32
Rich E Forum Admin
Grooved discs give you a much improved initial bite and help at high temperatures, but do indeed cause additional pad wear.
It just really comes down to whether or not you feel the improvement in initial bite is worth the extra wear.
Oh, grooved discs make a cool noise too Cool Yes Whistle
Posted 18th Nov 2013 at 22:57
Rich E Forum Admin
Oh, to clarify, people who say 'I figure' or 'probably' clearly have not used any of these sort of products themselves and have no clue. Thumbs up
Posted 18th Nov 2013 at 23:02
jimmyhackers
say it to specifically to me and not to "everybody" otherwise you just seem like a dick otherwise.
i never like to %100 anything hence using phrases like that. gives me a get out clause when some know it all knob face wants to proove he knows more becuase hes had the option to post afterwards
Posted 19th Nov 2013 at 00:25
beez_neez_gt
+1
I noticed a good amount of bite, wear does depend on which pads you use.
Never touch drilled because during hard use they do tend to crack.
Disks with less grooves don't make much noise its the ones with lots of grooves that make the noise iv found, I only use grooved myself.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 28th Nov 2013 at 02:13
