Author Subject: Brake upgrade, what calipers?
Nose
Hi guys, typical newbie question, I've searched FAQ's and can't find what i'm looking forNo What calipers and discs would be a direct fit onto my Rallye. I can see many threads on sooooooo many brake set up's, but is there a particular set up to use; ie discs from a 406 Coupe and calipers from a bmw530i etc.
cheers all.
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 5th Nov 2013 at 23:07
rich306
I've heard the Brembo 406 calipers are a nice way to go
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 6th Nov 2013 at 07:58
A good performing setup is Brembos from a 406 Coupe along with Xantia 288mm discs.
You would need to ensure that your particular wheel fits with these though as not all do. The only downside to this setup is they are known to squeal A LOT.
This is generally only under light braking though, so if you were only looking for track use where they would be used heavily then it wouldn't be an issue. Smile
Posted 6th Nov 2013 at 09:43
fordygti
I've got some nice 225 Renault sport calipers with everything you need to get them running. Whistle
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 6th Nov 2013 at 10:56
Nose
Many thanks for the offer, but i'm just asking at the moment Thumbs up
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 8th Nov 2013 at 20:52
aaron6
I personally will be going for a willwood set-up so I can keep my clones and not run stupid spacers.
Posted 9th Nov 2013 at 07:34
That's ok, but for track use I'd recommend a larger diameter combination especially to help dissipate the extra heat generated on track. If you're not going to visit the track then they'll be fine.
Seeing as you're main event is Pugfest, they'll be great for that though. Thumbs up
Posted 9th Nov 2013 at 10:30
aaron6
They should still be a decent improvement on standard setup id have thought. Im also contemplating stripping mine and starting track days but would still want to keep the clones. Im sure willwoods and good pads would be sufficient. A lot of people still use standard stuff on track with few issues. Its the problem with 15s. Choice is limited.
Posted 9th Nov 2013 at 11:28
Indeed, they will be a big improvement over the standard setup - I would just rather have a bigger setup to ensure overheating/fade was kept to a minimum, or in the case of 330's it's zero.
Would be good if you did decide to hit the track mate, I'm sure you'd love it. Yes Smile
Posted 9th Nov 2013 at 12:10
Nose
Hi Stan, would this set up fit under my cyclones bud? and would they bolt straight on or is there a bracket to be made Dunno
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 11th Nov 2013 at 19:51
aaron6
You'll need 20mm spacers to fit under cyclones.
Posted 11th Nov 2013 at 21:15
Nose
Thanks Aaron, i thought as much, cheers.
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 11th Nov 2013 at 23:39
osm2121
This is interesting. What Willwood´s are you talcking about? Y´d like to improve a bit the brakes, and want to keep the Cyclones. 20mm spacers sound too much for me, so... What is the Willwood´s model you´re talking about? Are they a direct fit?
Posted 11th Nov 2013 at 23:45
aaron6
Iirc thet bolt on but require 10mm spacers. Its the midlite caliper btw. Wink
Posted 12th Nov 2013 at 07:07
allye
If you're going to spend serious money on calipers, don't buy Wilwoods, they are a bit s**t in comparison to say 2nd hand set of Renault sport Brembo's or similar.
205 Van SC'd GTI6 - because why not
309 Goodwood V6 - sold
205 Rallye GTI6 - Bent
Posted 12th Nov 2013 at 08:42
aaron6
The point is, if you want to upgrade and want to keep cyclones the set up you mentioned wont work. Wink
Posted 12th Nov 2013 at 09:17
Is keeping the cyclones really that important? Surely by changing the wheels to give you more brake flexibility would benefit the whole package.
Posted 12th Nov 2013 at 09:30
aaron6
I love the way my one looks on cyclones and bigger means more money for the tires I like which negates why I got a 6. Which was to save on running costs as the impreza was a touch expensive. Alrhough I do agree with you to a point. Smile
Posted 12th Nov 2013 at 10:07
aaron6
Plus I think 15 aftermarket wheels look s**t. Especially prorace 1.2's
Posted 12th Nov 2013 at 10:08
Yes, I'm with you on the fact that aftermarket 15's look wrong - they have to 17's in my opinion to have the right cosmetic impact. Yes
I know Damien used to run the Wilwoods under cyclones and he loved the braking. Didn't seem to help much at the second hairpin at Pugfest though when they were digging him out the gravel trap...Whistle
Posted 12th Nov 2013 at 10:21
demondriverdan
I think the KAD 6 pots fit under clones as well, but I'm not 100% sure on that! Although they're pretty rare second hand.
It's a bit of a compromise when it comes to brakes, especially under 15"s. I guess the obvious question has to be asked but have you tried with a decent set of standard pads and discs first before upgrading?
Rallye Race Car
Posted 12th Nov 2013 at 12:59
aaron6
Just doing that as we speak. Still would like more though. As for digging damian out... think he just ran out of talent! LOL
Posted 12th Nov 2013 at 15:07
aaron6
If im honest, at the relatively low speeds at pugfest, my srandard brakes havent been an issue. Its the higher speeds where they seem to fade out a bit under very heavy use. Which dont happen too often. The kad ones are rarer than rocking horse s**t which is a shame.
Posted 12th Nov 2013 at 15:11
Carbon lorraine RC6 pads work well in standard calipers, if you can live with the dust.
If you are prepared to do your research and design your own setup then you can get reasonable size 4 pots under 15's, but it won't be a cheap setup, and cyclones will make life a little more difficult. Wink
Posted 12th Nov 2013 at 17:07
superchargedblack1997gti6
guarantee Kad 6 pots fit under as I used to own them have sold them to Rallyeash now
but they fit under cyclones with no spacers,
Posted 12th Nov 2013 at 17:23
