Author Subject: Crankshaft Oil Pump Sprocket
bruce2007
Just confirming that this is just held on by clamping force of the crankshaft pulley bolt? Just seems a bit odd, never seen it done without a keyway before!
Posted 3rd Nov 2013 at 12:01
jeffers Forum Admin
Sounds like you have the old two piece item, il see if I can dig out the part number for the one piece newer item, oh and there should be a woodruff key! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 3rd Nov 2013 at 12:09
ryangti6
I didn't think there was a key on the older style hence people change to the newer as It's considered better.
Pretty sure your right that it is just clamped by the pulley bolt to be honest but It's been a while since I've had one apart
Ryan
Posted 3rd Nov 2013 at 15:20
Ryan - There is a key on both parts. Yes
However, on the early type it's only the 'spacer' part which is keyed with the woodruff, and it's the clamping force which turns the sprocket.
On the later style, the spacer is keyed again, but this time the spacer and sprocket are one piece so the sprocket is keyed by the fact the spacer (which is now part of it) is keyed.
Posted 3rd Nov 2013 at 15:36
cully
early type is held by clamping force of the pulley bolt the sprocket has no key only the spacer is keyed
i have an engine stripped here if you want pictures
0513 78 PUMP CONTR PINN 26 DTS + UP TO O -08280 0514 92 (1)
Posted 3rd Nov 2013 at 16:03
bruce2007
Cheers guys much appreciated. Could someone confirm the new style part number so I can get a price! Also, opinions on if its worth changing to the new style?
Posted 4th Nov 2013 at 11:42
Rich E Forum Admin
As per Cully's post above:
0513 78 - PUMP CONTR PINN - RRP £16.58 + VAT
0514 92 - RUBBER SEAL - RRP £0.39 + VAT
Given the cost I would change over to the new type if you have the engine apart.
Posted 4th Nov 2013 at 12:18
bruce2007
Ah apologies, on my phone and missed cullys post completely! Cheers, yeah for the sake of 20odd quid Ill get on ordered!
Posted 4th Nov 2013 at 12:24
