Author Subject: Returning to Standard Ride Height
RetroPug
Assuming the suspension is all in good working order and has recently been fully rebuilt, what would be involved in returning it to the std. ride height if both the rear beam and the front springs were lowered 40mm?
New OE springs at the front would obviously be needed. What actually sets the right height of the rear beam?
Thanks
Posted 2nd Nov 2013 at 13:16
jord294
The torsion bars
Posted 2nd Nov 2013 at 13:19
RetroPug
So new OE springs at the front, and at the rear I'd need to remove the shocks, support the beam on a trolley jack, remove the TBs and then move the trailing arms so that the distance between the damper bolts is the standard 330mm, re-insert the TBs and refit the shocks?
Posted 2nd Nov 2013 at 13:49
jord294
Yep. Basically it. But, unless you know the history of the beam, I'd rebuild it.
By setting the arm to a different position can increase the chance of wear on the bearings and shaft
Posted 2nd Nov 2013 at 13:55
RetroPug
Thanks.
I'm looking at a car that has a refurbished rear beam, but it is also lowered on spax springs and the rear beam has been lowered to suit. I'd far rather have standard suspension or at least closer to it with uprated bits, as I think the current setup isn't perfect handling-wise and I'm not such a fan of the aesthetics of excessively lowered cars anyway.
Would OEM-replacement springs like these from KYB be of decent enough quality, or would I really need to go for OEM Peugeot, slightly lowered aftermarket ones or another brand?
Oh, and tools-wise, I'd be fine with sockets, spanners, a mallet, axle stands and a trolley jack?
Will I need something a bit heftier than a rubber mallet to knock the TBs out?
Posted 2nd Nov 2013 at 14:19
jord294
i'd go genuine springs on the front and genuine rear shocks
instead of buying new, buy off someone who has removed standard springs and fitted lowered ones. if they are a bit tatty, just get them powdercoated Thumbs up
Posted 2nd Nov 2013 at 14:23
RetroPug
Are used springs going to be nearly as good as new ones? And better than decent-brand pattern ones like KYBs?
Posted 2nd Nov 2013 at 14:44
jord294
there are 4 different springs listed for the gti with peugeot
if you go pattern part, there'll probably only be one
Posted 2nd Nov 2013 at 15:34
RetroPug
Yep, fair point, but then any secondhand one could be any one of these part numbers.
I guess they might have changed the springs between phases. I'd be surprised if they weren't all suitable though.
Thanks for the help.
Posted 2nd Nov 2013 at 16:07
scotzman
I think Rallye's are listed as different springs too, that huge weight reduction makes a difference. LOL
Posted 2nd Nov 2013 at 16:19
RetroPug
Could be each phase and one for the rallye I guess yeah, although in reality they're only likely to just have slightly different spring rates?
Posted 2nd Nov 2013 at 19:23
