Author Subject: knocking on drivers side suspension
cornish_pug
Hey guys, seemed to have picked up a knock on my drivers side suspension area. Shock, spring, wishbone are all recently new. The noise is worse if I drive over uneven ground on passenger side. Could this be a drop link isue?
Team Diesel
Posted 30th Oct 2013 at 19:51
Checked your hub nut is tight?
LOL
  • Posted 30th Oct 2013 at 20:08
    cornish_pug
    It's as tight as it can be so I can get the R clip on in its correct position. There's no play in anything that I can see.
    Team Diesel
    Posted 30th Oct 2013 at 21:18
    ryangti6
    Are you sure It's from the suspension not the top engine mount? Easiest way to check other than visually is see if going on and off the power makes the noise happen.
    Drop links tend to be more of a rattle than a clunk
    Ryan
    Posted 30th Oct 2013 at 23:54
    It sounds like it could be a drop link. Yes
    But do what Ryan says and make sure you don't get the knock on and off throttle.
    Posted 31st Oct 2013 at 07:10
    My diesel clunked its tits off and nothing was loose etc. I thought top mounts, but turned out to be the drop links. I would give it a try, cost me less than £20 and less than an hour to change them Yes
    Posted 31st Oct 2013 at 13:30
    cornish_pug
    cjm_harris, they're of the plastic type. They were new about 2 1/2 years ago. i'll take them off and see what they feel like before buying anything.
    Also ryan saying that I do get a click when I power up sometimes, so I'll have a look at the top mount too to see if everything is fine.
    Team Diesel
    Posted 31st Oct 2013 at 15:48
    daver6
    I've got a knock, but on near side.
    I felt the captive nut whilst I put a bit on the bolt and felt the captive nut was moving... not so captive.
    I'm hoping this will sort mine.
    I get clunks whilst braking and accelerating
    Wishbone Polybushes available
    Posted 31st Oct 2013 at 21:16
    sixysix
    I would say droplinks as well as knackered ones always sound bad over rough ground.
    Also cheap and fairly easy to replace yourself.
    I have lost count how many times I have replaced links, and these things can go pop very quickly depending on the state of the roads you drive on.
    Take a look
    Posted 1st Nov 2013 at 22:37
    parrotno1
    I would also say droplinks, had same noise your describing. One of my droplinks was buggered and made car feel a little `wallowy` around corners. Droplinks replaced and feels good again and no noises.
    Posted 18th Nov 2013 at 20:53
    jimmyhackers
    i had it on mine. was drop link, grab it and give it a good tug a ragg about, sometimes it takes more force than you think to make such a little rattle or clunk appear.
    Posted 19th Nov 2013 at 23:07
    tvrfan007
    Droplink likely, though when i changed my passenger side last time it didn't help - turned out the balljoint was to blame. Knocked its tits off on uneven ground.
    I'm Si btw Tee hee
    Night Blue VW Golf GTD
    Posted 24th Nov 2013 at 13:05
