Author Subject: Rear caliper handbrake actuator
mjt4130
I m trying to rebuild a rear caliper after removing the handbrake actuator arm. Stuck on how to get the little cam piece back in between the actuator arm and the caliper. Any Ideas?
Posted 28th Oct 2013 at 12:21
This is a nightmare job and that is no exaggeration!
You need to place the fatter end of the cam piece in the twist part on the rear of the piston and then attempt to slide in the actuator arm. Yes
It really needs a vice on a bench to hold the caliper body (use plenty of rags to avoid damage) and then I use a large bar to lean down onto the actuator arm as I tap the bottom of the arm back into place.
You will swear at it - it's an absolute ballache of a job. Sad
Posted 28th Oct 2013 at 13:40
skoob
Attempted this myself, ended up giving up and getting refurbed lol
Posted 28th Oct 2013 at 13:43
mjt4130
Going to give it an hour of my time then- Wish me luckSmile
Posted 28th Oct 2013 at 13:58
daver6
Can't you remove a shim to make it easier?
Wishbone Polybushes available
Posted 28th Oct 2013 at 15:39
Niall
This when i did mine, lots of swearwords were heard by all my neighbours!
i used a big flat head screwdriver to lean on the shims and eventually JUST slid it over the cam. Not a job i will be doing again in a hurry!
Just make sure you have cleaned it all up really well and just before you put the new boot on, pack it full of grease.
Posted 28th Oct 2013 at 17:56
mjt4130
Done it. Gave up and removed a shim, not ideal I know but its together and working!
Posted 29th Oct 2013 at 21:47
LOL
You cheated! Smile
Posted 30th Oct 2013 at 08:37
daver6
Sensible lad! Thumbs up
Posted 30th Oct 2013 at 17:15
Was gonna say if not I'll have 2 callipers for sale soon with free bleed nipples
Posted 30th Oct 2013 at 18:10
Put the f**king belleville washer back in, it's not a shim.
Posted 31st Oct 2013 at 00:23
mjt4130
Might have another go at doing this properly- The internet is not happy with my botched attempt.
(V)(;,,Wink(V)
Posted 31st Oct 2013 at 21:41
Yes, I'm afraid Bendix didn't put them in there just because they had 10,000 spare on the shelf they needed to shift.
Posted 31st Oct 2013 at 22:14
daver6
I've had them built -1 shim/belleville washer and didn't see any adverse effects after +20k.
The piston was sat correctly, the handbrake worked, no wear when I last checked them and the actuation of the handbrake was also fine
Posted 1st Nov 2013 at 07:33
It was still put there for a reason though Dave and should be refitted. Yes
I know it's a ballache to build the caliper but it is doable and therefore should be done.
Posted 1st Nov 2013 at 09:11
daver6
Doesn't make any difference to me. I'm saying that I once rebuilt without (because I lost.one) and suffered no ill effects.
Posted 1st Nov 2013 at 09:54
Hmm
I believe their job is create resistance in the handbrake mechanism and therefore give it a helping aid to release. Have you found yours still releases the same as before?
Posted 2nd Nov 2013 at 09:18
daver6
Yeah, everything works as it should
Posted 2nd Nov 2013 at 17:10
daver6
Posted 2nd Nov 2013 at 17:11
