Author Subject: VTS rack
pugheaven
Just wondering what part makes the rack a "quick" rack?
If I was to change the part below that was removed from a 6 rack and fitted it to a vts rack would it turn the quick rack back to the same ratio as a 6 rack or would it still be a quick rack?
Posted 20th Oct 2013 at 11:30
Rich E Forum Admin
Racks and pinions come as matched gear pairs. If you tried fitting a different pinion gear it would probably just lock up and not move at all. The teeth would not align.
Posted 20th Oct 2013 at 11:55
pugheaven
Yep iv just took the vts one apart and found that they are completely different size rack and pinions... Great....
The thread for the low pressure pipe has been cross threaded, I guess that's the first thing I should have checked before changing the rods over!
The previous owner wouldn't have known as im assuming he received the rack with the pipes already removed Sad
Im going to try and tidy the threads up but its not looking likely Sad
Posted 20th Oct 2013 at 12:03
superchargedblack1997gti6
Ollie I can get this machined out and an insert put in and tapped if you need?
Unfortunately I never got this one fitted.
Posted 20th Oct 2013 at 12:13
What Rich said, the rack and pinion are matched, the pair together are what makes it a quick rack, putting that pinion on a standard rack will just lock it solid.
Posted 23rd Oct 2013 at 12:28
c_j_m
http://306oc.co.uk/forum/thread-18204.html
This shoud be of some use. Shows you how to disassemble that part of the rack and you could change over the damaged housing?
Posted 23rd Oct 2013 at 14:19
pugheaven
Iv already done that but the housing is machined out a lot larger to accept the larger pinion
Posted 23rd Oct 2013 at 18:35
c_j_m
Ah worth a shout though.
Posted 23rd Oct 2013 at 19:31
