You could with that, that shan't be moving for a very long time...
Richies Project RallyeElectrical work carried out in Portsmouth
displaying posts 26 to 36 of 36
Pages (2): 1 [2]
| Author | Subject: Wheel bearings. |
rich306
Seasoned Pro Location: Portsmouth Registered: 09 Aug 2009 Posts: 1,834 Status: Offline |
stan_306gti6 wrote: ![]() You could with that, that shan't be moving for a very long time... ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
mattgti6phase2
Seasoned Pro Location: inside my 6 abusing the tarmac!! Registered: 16 Jul 2010 Posts: 2,371 Status: Offline |
Had a good look today and i found DS to have TRE movement and PAS side to have wheel bearing movement. Easy fix so will sort those tomorrow and hope she flies through her MOT next week ![]() ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
stan_306gti6
I told you that PS was wheel bearing movement...________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
mattgti6phase2
U said the hub but was loose?? ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
stan_306gti6
Yes, and by tightening it up you will remove that play. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
mattgti6phase2
I haven't tightened it though bud. The wheel bearing is f**ked it's not the hub nut at fault. ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
Wheel bearings do fail unfortunately. If only tightening hub nuts worked every single time ![]() ________________________________________ ![]() |
stan_306gti6
Obviously if a wheel bearing fails then yes, it'll need replacing.However, a lot of the time a bearing hasn't failed but the hub nut requires tightening to get rid of this movement. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
mechanical_repairs
stan_306gti6 wrote: Obviously if a wheel bearing fails then yes, it'll need replacing. However, a lot of the time a bearing hasn't failed but the hub nut requires tightening to get rid of this movement. You sound like your talking from experience? Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
dcc
Senior User Location: Wales Registered: 24 Feb 2009 Posts: 502 Status: Offline |
Post #35
a wheel sealed bearing should never need tightening if it was tightened sufficiently and pinned in the first place. Sounds like the bearing is f**ked. over tightening the hubnut is likely to kill the bearing off for good.Stan I think you're wrong here. Get the bearing changed for a decent quality replacement, not a cheapy Chinese thing, else you'll be 'for ever tightening those hubnuts'... ________________________________________ 205 GTIXsara HDI |
mattgti6phase2
Post #36
It's been replaced. I done it last week now also replaced the TRE's as a pair even though only 1 was mullered. As said i didn't crank the hubs nuts up as iirc they should only be done up at 265nm which is what i put them to. ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
Pages (2): 1 [2]
