Author Subject: strut top to shock piston.
beez_neez_gt
Iv fitted some new shocks and realised iv missed out the washers that fit into the rebound mount and on top of piston shoulder at bottom of its threads, threads out of top mount looks to have more of them popping out than it used to have but tightened up fine.
Will it really make any difference not having the piston washer fitted and would it make the car any lower due to it being missing, top mount cup that rests on shoulder of the top of shock piston went on fine and looking through manual diagram this washer looks missing ??
Or will it just wear the rebound mounts out quicker ?
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 12th Oct 2013 at 19:59
The washers on the damper rod you mean, that go under the strut top mount?
Posted 12th Oct 2013 at 20:11
beez_neez_gt
Yes they fit into rebound mount and rest on shoulder at bottom of the threads.
Pug fee`ver,
Posted 12th Oct 2013 at 20:14
I'd put them in as they are supposed to be there ?
Posted 12th Oct 2013 at 20:34
Yes, they're there to spread the damper load into the top mount.
Posted 12th Oct 2013 at 20:39
beez_neez_gt
Ok its just one iv done, noticed it when doing the other, so least I only have to sort and take the other out.
Pug fee`ver,
Posted 12th Oct 2013 at 21:20
School boy error !
MTH !
Posted 12th Oct 2013 at 21:23
beez_neez_gt
Totally, have lost one so ill use 205 ones which are in better nick.
Pug fee`ver,
Posted 12th Oct 2013 at 21:40
Hmmm
Did you take the old struts apart before you had the new ones ?
Posted 12th Oct 2013 at 22:01
beez_neez_gt
Coarse but one shock is newish n other original I think, new one had piston cover missing so bodge job on vts years ago.
Pug fee`ver,
Posted 12th Oct 2013 at 22:04
So you have one old original shock and one newish badly put together shock possibly from a vts but may be from something else ?
Posted 12th Oct 2013 at 22:15
I doubt it has the piston cover missing, might have the rod cover gone however Whistle
Posted 12th Oct 2013 at 22:54
beez_neez_gt
Both old ones came from a phase 1 vts broken up. One ie newer one was leaking so bought a new set and kept springs. So missing washer must have not been put on the newer one of which was the first one used to fit on 205, ie spring from old one.
Doesn't matter anyways I still have to pop strut out and fit washer.
Tomaatoe tomaahtoe whatever LOL
Pug fee`ver,
Posted 12th Oct 2013 at 22:59
