A couple of months ago I replaced the CTS which cured the issue...for about 2 weeks. I've also cleaned my ICV but do not know whether it is functioning properly or not.
I have changed the plugs and posted a picture of the old plugs which I was told looked healthy.
At the start of the year the car was hit and written off...after fixing it and driving it for a bit it lost coolant and overheated..I assumed this was a leaky rad from being hit so replaced it, and it didn't ever overheat again.
Old air filter was pretty clogged as where I was over summer was very dusty, and the lazy starting did begin in summer. New filter is going in soon, so will see if that helps.
What would be the best way to proceed? What tests should I do to definitively rule out the HG having failed or to detect it? Can I test my ICV with a multimeter? If so, how? If I get a sniff test done, and it says it is fine, will this be a definitive proof that the HG is sealing properly? If I run the car for 15sec before it can heat the coolant and then remove the rad cap and it has pressurised will that indicate that the HG is gone?
Really not sure what to do, but want the car to run properly. Other than slightly rough idle, it pulls fine through the whole rev range.
RetroPug
