Author Subject: 30mm arb machining
greenie
So Ross saved my bacon again by letting me have a pair of good vts trailing arms after I discovered my shafts were shafted.
As the shafts of the 'new' arms need to be pressed in I am considering getting the machining done to allow a 30mm arb later on. Is it as simple as turning the inner diameter of the shafts out so that they accommodate the 30mm bar.
Thanks for your advice and daft comments in advance !
Posted 6th Oct 2013 at 14:27
allanallen
Yep, bore them out to just over 30mm
Facebook
Posted 6th Oct 2013 at 15:30
greenie
great thanks allanallen
Posted 6th Oct 2013 at 16:17
miles
New one's are another way, the OE ones current and the Febi ones have large enough holes in
www.pugracing.com
Posted 6th Oct 2013 at 16:19
greenie
Oh ok
good info, thanks
how do I establish left and right handed shaft or does it not matter?
Posted 6th Oct 2013 at 17:32
miles
Makes no odds when new, Only the factory spec beams had the silly hole sizes, God knows why as it would cost more to make and more part numbers
www.pugracing.com
Posted 6th Oct 2013 at 21:07
greenie
I have two decent second hand shafts that I intend to use, I cant afford to go and get new. They are slightly different on inspection which is why I suspected they were l and r handed.
Does it matter which side they go in ?
Posted 6th Oct 2013 at 21:16
jord294
It doesn't matter which side they go, aslong as you press them in in the correct way
Posted 6th Oct 2013 at 22:16
greenie
Thanks Jord, all done today. Refit tomorrow.
Posted 7th Oct 2013 at 21:06
