Author Subject: Master cylinder blank plugs
mjt4130
I m collecting parts to bin my ABS and use a bias adjuster. Are there specific blanking plugs available to plug the master cyl when I remove the redundant lines?
Posted 4th Oct 2013 at 20:58
There are only 2 lines from a gti6 master cylinder ? I've never seen or had a bias adjuster so no idea if use just one line ?
I thought if you binned the abs you need a 4 line master cylinder ?
Posted 4th Oct 2013 at 21:06
you don't need the 4 line one. i ditched my ABS keeping the std gti6 2port MC - front port to front lines split via T piece, rear port to a valve then out the back of the valve to a T piece and to each rear wheel
Posted 4th Oct 2013 at 21:14
demondriverdan
Seems to be the common way of doing it, I'm doing the same with mine next weekend.
Rallye Race Car
Posted 4th Oct 2013 at 21:18
You can buy specific blanking plugs should you need them. Yes
Posted 5th Oct 2013 at 09:23
