Author Subject: sillicone air intake pipe?
jameswallace.
Does anybody make one of these? Just to make it clear im talking about the pipe in between the inlet and the air filter. I would think that somebody must have done it? But cant seem to find one. Id assume it would look similar to this....
http://item.mobileweb.ebay.co.uk/viewitem?sbk=1&nav=SEARCH&itemId=321072177019
Posted 1st Oct 2013 at 20:29
Niall
im after something similar. I have a silicone hose for my induction but i might get a screw in bit of pipe so i can fit the ICV hose into it.
Posted 1st Oct 2013 at 20:31
jamiek_uk2000
With the price of that, I'm sure people would rather just put a separate filter on the ICV. I know I would.
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 1st Oct 2013 at 20:39
jameswallace.
Ahh yeah thats a really good idea. Where did you get your hose from?
Posted 1st Oct 2013 at 20:40
jameswallace.
Also thats a good idea I didnt even think of that! Also the price wasnt really relevant that was just one that I had found. I assume they could be made up more cheaply
Posted 1st Oct 2013 at 20:42
jamiek_uk2000
I bet they could, I just bought a little filter off Ebay and that's how it's staying forever and a day now (Until I boost that is LOL )
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 1st Oct 2013 at 20:52
Niall
I got mine from ASH Hoses. They are great quality at half the price of Samco ones
Posted 1st Oct 2013 at 20:53
Did this with mine as I had a stainless bend kicking about off the EvoWink
Then just bought a 45degree elbow from E-BayThumbs up
Posted 1st Oct 2013 at 20:55
jamiek_uk2000
I think I may have missed the original point then, I thought you just meant a 90 degree bend with the extra point for the ICV? You can get a 90 bend from ASH, I've got one now which is different size at each end (Can't remember which way round, think it's something like 70/83mm for the throttle body/induction filter)
You can see what I mean about the filter on the ICV from that photo
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 1st Oct 2013 at 20:59
90 degree bend will be no good,unless you use a non standard top rad hose.Thumbs up
Posted 1st Oct 2013 at 21:01
jamiek_uk2000
It's what's on my car now.....
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 1st Oct 2013 at 21:02
PicsDunno
How does it clear top hose?
As you can see in my pic a sharper bend would foul the pipeYes
Posted 1st Oct 2013 at 21:04
jamiek_uk2000
I'm in London and my car is having spray work done back at home in Llanelli. I couldn't be further away from it. I'm back in two weeks if that is any use? IIRC Because I have taken the snorkel off and had a cold feed from the front fog then there is room for the bend to go straight onto the TB and then I used a longer elbow to take the induction further down. That's from what I remember though. And I have been known to be an idiot
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 1st Oct 2013 at 21:17
My old cone filter used a 90 degree ally bend. It didnt aim down but backwards to where the battery would normally be. I think it's very close to the rad hose but dont think it touches, i did keep cutting the ends of the bend to get it to sit right though.
I think i read on here that it's ideal to keep as much of the inlet as metal rather than silicon etc as they absorb some of the induction pulses.
Now i'm using a similar setup but with a pipercross viper filter, made a nice 182bhp 155lb ft from memory on a standard engine (as far as i'm aware). Smile
Just using a little filter for the ICV.
Posted 1st Oct 2013 at 21:39
jamiek_uk2000
182 on a standard engine? Hmmmm. Not from just an induction kit anyway.
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 1st Oct 2013 at 21:50
I bought the engine second hand from someone off here, was sold as standard. I've not looked at the cams but it runs a bit lumpy and hates 2k rpm, using my old ecu with it.
The exhaust is less than ideal, the centre box has a bore of 2". Doh
Posted 1st Oct 2013 at 22:29
allye
You can buy little take offs quite cheaply that attach to silicone hoses if you really wanted a take off for the ICV.
205 Van SC'd GTI6 - because why not
309 Goodwood V6 - sold
205 Rallye GTI6 - Bent
Posted 1st Oct 2013 at 22:39
With a induction kit?Yeah would be okThumbs up
Would not work with the standard airbox thoughNo
Posted 2nd Oct 2013 at 09:16
I used a 90 degree one on mine, but think I used an extra bit of straight pipe. 90 straight off the TB doesnt work...
I also just cut a hole in the straight bit of silicone pipe for the ICV pipe.
Also, with that setup to a nice air feed, and a decat free flowing exhaust made 180 bhp on 2 different rollers.
Obviously always take RR results with a pinch of salt, but showed my engine was healthy, and made power over standard.
Posted 2nd Oct 2013 at 15:40
cully
i fitted a flexible silicon and a small ash breather filter
filter fits directly onto the ICV and the pipe fits directly on the std airbox and manafold
Posted 2nd Oct 2013 at 18:41
henrik c
On my GTI there are used some downspouts in ø75mm - pics to follow
/Henrik C
Posted 3rd Oct 2013 at 13:52
