Author Subject: Cone Filter in Standard Airbox
RetroPug
Hi,
I know induction has been covered 9999 times...but this is a slightly different question to "what is the best?".
Does anyone know the best cone filter neck diameter to fit the standard intake pipe leading from the airbox to the TB? I'd like it to fit in the standard airbox but also be a good seal and filter effectively once in place.
Of course, I could take it off and measure it etc and then order something but then I'd be left with a filterless car that I don't want to drive for longer, which isn't a desirable option. Also, if I remove the resonator on the airbox, am I correct in understanding that getting a plate welded over the hole is my only real option for bunging it?
Thank you.
Posted 1st Oct 2013 at 16:03
fatlapit
There is no real gains for removing the resonator
Posted 1st Oct 2013 at 17:39
I used a Tiger sealed plate over mineThumbs up
Resonators main job is to quieten intake noise,removed mine from airbox and inlet manifoldSmile
Posted 1st Oct 2013 at 20:59
jamiek_uk2000
I've read so many conflicting idea's on resonators that I've just left it in. I can't see the case for it's removal being massive and having much effect on performance to be honest
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 1st Oct 2013 at 21:01
Can't see any performance gains,but deffo more induction noise without themYes
Posted 1st Oct 2013 at 21:03
jamiek_uk2000
I hate the sound of my induction. If it wasn't for the power gains then I would be on an airbox. Add that to the Jetex and I just want to climb inside myself when I drive through town centres
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 1st Oct 2013 at 21:23
Power gains ?
Posted 1st Oct 2013 at 21:28
Jamie - You would get more of a power gain using the standard air box than an open filter, as long as you had a decent cold air feed to it. Yes
Posted 1st Oct 2013 at 21:47
jamiek_uk2000
With a cold air feed an induction gives cleaner revs than the airbox does.
Looking for:
VTS P1 Rack
PR1.2 16"
RetroPug
In any case, does anyone have any idea on a suitable neck size? Know the diameter of the hole in the top of the airbox? Know the space available inside it?
I basically just don't really know which cone to order without dismantling the whole thing and looking, and was wondering if anyone has any information like this to hand.
I'm not looking for performance gains...
My air filter likely needs changing once I manage to get the seized airbox-bottom off, and spending the same money as on a replacement k&n or pipercross etc. I could get a cone filter and have a nice induction note without any real loss in power, without spending any extra money, if anything spending a little less as cone filters alone seem quite cheap.
Posted 1st Oct 2013 at 23:15
mattgti6phase2
76mm OD.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 2nd Oct 2013 at 23:28
Not in my experience with these enginesNo
Had two Rallyes at one point one with induction,one with standard airboxWink
Standard airbox did not restrict the engine,much better throttle response,more part throttle response,more low down torque Yes
Induction kit is just for noise!Smile
Posted 3rd Oct 2013 at 09:39
RetroPug
mattgti6phase2 wrote:
76mm OD.
Cheers mate, so the same as it is at the top then?
Hence it seems like a decent idea to have a cone in the standard airbox thus keeping the same inlet tract and heat shielding but having a cone filter instead of std. circular for a bit more noise.
Posted 3rd Oct 2013 at 12:45
jamiek_uk2000
What you need low down torque for? Keep it in the red! Smile
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 3rd Oct 2013 at 13:30
Indeed, agree with Coskev, an air box with a reliable cold air feed is the best for power. Yes
Posted 3rd Oct 2013 at 14:44
mattgti6phase2
76mm OD.
Yes indeed sir.
5 x a 306 owner!
Posted 3rd Oct 2013 at 23:11
RetroPug
Thumbs up
Posted 4th Oct 2013 at 00:09
