Author Subject: can u put any bigger axles on to my gti6
daleharland01
just wondering if any one could let me know if i could fit a bigger axle on to my 6, i have herd a 406 would fit but just not really sure, i have got a spare 306 that has had good bushes and solid mounts on all ready to bolt on, and maybe get spacers. any help would be good cheers.
Posted 27th Sep 2013 at 18:49
pebbles167
Very few people (none) have done this as far as I know. You could use wide spacers, or if you have large amounts of disposable income, pugsport do stuff that would serve purpose.
Out of interest, what are you intending to make with this? Wide arch 306 for looks? Or would you be wanting to use this as a performance car?
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 28th Sep 2013 at 16:13
pugheaven
The 406 has independent suspension and not a beam so I'm interested in how others have done it if they have??
Posted 28th Sep 2013 at 12:48
rallyeash
Why would you want to?
Front wants to be wider than the rear!
309 3dr K20 Type R
Posted 28th Sep 2013 at 14:02
allanallen
As welshpug can't afford to be here I'll briefly stand in...... 306 rear beams are independant!
406s use a coil spring and arm arrangement rather than trailing arm and torsion bars. It's completely different and won't fit unless you're handy with a welder.
Facebook
Posted 28th Sep 2013 at 20:31
mik
Well it is sort of independent in that each wheel station can compress individually, but a beam type suspension as found on the 306, Golf etc is probably better described as semi-independent, as it is rigidly connected to the other wheel station. The MacPherson strut setup at the front is fully independent.
And back to the OP question, can't see what you are attempting to accomplish by putting a 406 axle on there. Pug engineers did a good job refining quite a basic design and it works very well.
Cherry Rallye SOLD
Posted 29th Sep 2013 at 00:28
No it is not.
The 306 rear beam is fully independent.
Posted 29th Sep 2013 at 01:19
beez_neez_gt
No not fully, no suspension is fully independent, it has an ARB that connects each arm.
Why on earth would you want it, would be far easier to get satchell to fit a hybrid evo system like he has on 205's.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 29th Sep 2013 at 07:17
pugheaven
If you want a wide tracked 306 just buy my split rims and job done
Posted 29th Sep 2013 at 13:42
It may not be dynamically independent, but it is geometrically independent, which is how the systems are generally described.
Posted 29th Sep 2013 at 13:49
