Thanks for reading and help.
FB: South Downs French Car ClubDiablo 6 2001 low boost
Diablo 6 2000 100% standard working air con
Vw Caddy tdi work van
| Author | Subject: xsara subframe. |
jmh306
Regular Location: Eastbourne Registered: 03 Aug 2009 Posts: 321 Status: Offline |
Hi guys. I have search with no joy and many be a stupid question but I'm breaking a xsara ph1 and was wondering if the sub frame is the same as on my ph3 gti6. Thanks for reading and help. ________________________________________ FB: South Downs French Car ClubDiablo 6 2001 low boost Diablo 6 2000 100% standard working air con Vw Caddy tdi work van |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
yup, same part number.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
They are the same. The Xsara one will have some clips on to hold pipes down which yours probably won't have. May as well leave em on and make use.________________________________________ ![]() |
jmh306
Thank for the quick response and info. ________________________________________ FB: South Downs French Car ClubDiablo 6 2001 low boost Diablo 6 2000 100% standard working air con Vw Caddy tdi work van |
blandy
Out of interest Is the whole front suspension the same as well I.e wishbones, hubs etc? |
not quite.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
welshpug! wrote: not quite. What is different out of interest? Thought something must be due to the difference in lengths of the track rods ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Length of balljoints and position of top mounts, afaik they use the 306 non pas BJ on the PAS xsara's, which explains the minor difference in driveshaft lengths.so front track is ever so slightly narrower, though the rear is all the same. explains why I have nice camber on my ZX, as I have 306 PAS balljoints :________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Hub geometry itself is different also isnt it? Not as much of a concern perhaps if you change both sides.________________________________________ ![]() |
possibly, never checked them though.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
blandy
Ah thanks so only good bits are rear axle, subframe, steering rack etc |
shell, engine, gearbox....________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
