Author Subject: Junior power timer connectors
..To call them by their correct name.
I got my hand on an AEM wideband whatsit from Pugheaven today (cracking service - thanks) and I'll be wanting to wire it up at some point so I've done a bit of digging around and the junior power timer connectors are what I need.
My DTA has the handy sockets which Sandy Brown added when he made the loom.
It would appear that one is for the power and ground and the other to talk to the ECU perhaps. Only need the first plug connected but meh I'll do em both while I'm there.
Found the male connectors I need:
www.ebay.co.uk/itm/140823907137?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
I'm hoping I can crimp those pins with a standard pair of crimp pliers? Or do I need something a bit more specialist?
  • Posted 30th Aug 2013 at 22:15
    You need proper pliers to do them to a decent standard, especially in a car, you can get them for about £20 iirc, bought some years ago.
    Posted 30th Aug 2013 at 22:49
    bo***cks. For a one off it's not really worth my buying a set.
  • Posted 31st Aug 2013 at 08:08
    How soon do you want it done?
    Posted 31st Aug 2013 at 09:26
    Midday.
    LOL in no immediate rush, but within a couple of weeks would be nice Smile
  • Posted 31st Aug 2013 at 09:32
    pete_rallye
    Have you got a soldering iron? Once crimped just drop a dab of solder on them to secure them permanently. Be careful not to let the solder run up the wire though otherwise it can cause the wire to fail prematurely. A half decent crimp will probably do mind as long as your not yanking at the wires...
    Lap of the 'ring
    Posted 31st Aug 2013 at 21:07
    Received the connector and I imagine if I start attempting it with normal crimpers it's going to end in tears.
    Found these on eBay:
    http://item.mobileweb.ebay.co.uk/viewitem?itemId=321183289907
    Do the appear to be the correct sort of type?
  • Posted 4th Sep 2013 at 18:48
    dcc
    Dan out of interest did you find anywhere you can buy a male connector for these, with some wire out the end to solder the lambda sensor to?
    205 GTI
    Xsara HDI
    Posted 13th Sep 2013 at 23:56
