Author Subject: 205 Gti6 brake upgrade 1155 pads + braided lines
rallyeash
Hi all,
ive just removed the gti6 calipers that were fitted onto my 205 (uses 1.9 hubs) and upgraded to some 6pots so these are now spare.
1 pair of front GTi6 calipers fitted with Mintex 1155 pads which are a fast road/track pad and have about 10mm pad depth left, proper length braided lines which are slightly longer than standard 205 length to safely run the Gti6 calipers and they also have the proper female nut which sits correctly in the tab where the copper brake line meets the flexi. (hope that makes sense, does in my head!)
I do have a set of Gti6 discs that i can throw in, they have a few mm lip. Personally i would fit new discs but theres nothing actually wrong with these discs and would run again.
obviously can be used as replacement or 306 upgrade but from memory the braided lines will need changing to suit 306.
£85 collected from Wiltshire or Hampshire.
can post if required
309 3dr K20 Type R
Posted 27th Aug 2013 at 22:55
Roon
Would you sell the lines separate?
Posted 28th Aug 2013 at 13:48
rallyeash
£30 posted
309 3dr K20 Type R
Posted 28th Aug 2013 at 14:09
Roon
Sounds good how many miles have they covered and what's the make
Ask as I bought a set and 1 exploded after 2500 miles.
Posted 28th Aug 2013 at 14:22
rallyeash
About 500 miles, 450 of them around a circuit! No issues as I inspected them when I removed for any damage.
Can't confirm the make I'm afraid but they won't of been cheap horrible items on my track car
309 3dr K20 Type R
Posted 28th Aug 2013 at 15:54
Roon
Sounds good, if you Pm me your PayPal ill get that across.
Posted 28th Aug 2013 at 17:01
rallyeash
Bump. All available still
309 3dr K20 Type R
Posted 25th Sep 2013 at 08:33
vts_tibi
how much for the pads alone?
VTS
best 60' : 2.272
Team Trackday™
Posted 27th Sep 2013 at 21:04
rallyeash
£40 delivered to Hungary
309 3dr K20 Type R
Posted 28th Sep 2013 at 12:40
And how much just for the calipers bud ?
Posted 28th Sep 2013 at 15:00
rallyeash
£30 for calipers
309 3dr K20 Type R
Posted 28th Sep 2013 at 22:09
