displaying posts 1 to 25 of 43
Author Subject: Cambelt cover.
mattgti6phase2
As above I'm looking for a cambelt cover in good condition please. Mine has burn holes in it from when it was poorly fitted after my cambelt change and the aux belt has worn it away Whistle
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 22nd Aug 2013 at 22:11
I've got one Matt Yes
I assume I have the correct one to fit your phase 2, the one with the sliding mechanism on?
Posted 23rd Aug 2013 at 09:16
all the same Wink
Posted 23rd Aug 2013 at 09:49
gnrlee wrote:
all the same Wink
Really?
I thought I heard that some of them have 10mm bolts, and some have a sliding mechanism on? Not sure myself though Unsure
Posted 23rd Aug 2013 at 09:53
gnrlee wrote:
all the same Wink
Incorrect.
Earlier ones have a sliding mechanism where the others have 2 nuts to the centre.
  • Posted 23rd Aug 2013 at 10:14
    Well then Matt, need to check which you have. I have the sliding mech type, which is the earlier one according to Dan.
    Posted 23rd Aug 2013 at 10:36
    Here's the one I have available:
  • Posted 23rd Aug 2013 at 12:05
    And I bet that is the one he needs! Go away Dan Laugh
    Posted 23rd Aug 2013 at 12:10
    mattgti6phase2
    LOL LOL LOL that's the one i need!!!
    Although Dan is correct about them being different between the phases they are still interchangeable but the early type ones are s**t!
    5 x a 306 owner!
    Posted 23rd Aug 2013 at 12:27
    Thanks for ruining the sale of mine then Sad
    Laugh my ass off
    Posted 23rd Aug 2013 at 12:29
    mattgti6phase2
    Laugh my ass off sorry bud didn't realize
    Ok I'll try and salvage it for you.
    They work just fine, however the sliding mechanism interferes with the master cylinder resivour. And if Dan didn't have one I'd buy yours Wink
    5 x a 306 owner!
    Posted 23rd Aug 2013 at 12:37
    dangti6 wrote:
    gnrlee wrote:
    all the same Wink
    Incorrect.
    Incorrect, the actual cover is the same. Early types had a bar which fitted in the vertical slot and there were two 'bobbins' which fitted through the holes and the bar slid over these to lock it in place.
    The later type changed the bobbins for threaded bar and you need to affix it with two M6 nuts. Yes
    However the cover design is identical in both parts. Yes
    Posted 23rd Aug 2013 at 15:09
    Without splitting hairs - the fitment differs, so it's worth noting as had Matt purchased CJM's on GNRLEE's advice he could have got it and found he needed the mechanism fittings to the engine also which may or may not have been supplied in it's entirety.
  • Posted 23rd Aug 2013 at 15:16
    not identical, late covers will rub on the bolts of the earlier pulleys.
    Posted 23rd Aug 2013 at 15:26
    AWW Welshpug COME ERE!
  • Posted 23rd Aug 2013 at 15:32
    Do you mean the 3 x M6 bolts which hold the pulleys to the hubs?
    Posted 23rd Aug 2013 at 15:55
    yup, I fitted an earlier pulley on my inlet cam to make it easier to adjust, but they caught the inside of the later covers.
    Posted 23rd Aug 2013 at 16:25
    so Razz
    there's actually three different covers, one early type till RP 7664 with the slider, then two with the nuts changing at RP 08547.
    08547 is when the single bolt pulleys came in.
    Posted 23rd Aug 2013 at 16:31
    I stand corrected then...
    Seeing as I did your cambelt last week Matt I can confirm that your engine has the later style pulleys, so you will be looking for a cover which is post build code 08547. Yes
    Posted 23rd Aug 2013 at 17:38
    Said the man with the orthopaedic shoes.
  • Posted 23rd Aug 2013 at 18:01
    mattgti6phase2
    Is it the later 08547 one you have Dan?
    5 x a 306 owner!
    Posted 23rd Aug 2013 at 18:18
    that's not a part number, its the RP number of the changeover LOL
    Posted 23rd Aug 2013 at 18:38
    honestly3k
    Its a sad day when Matts 'Wanted Cambelt Cover' is the busiest thread on the forum LOL
    It's from a 2000 car so I'd suspect so.
  • Posted 23rd Aug 2013 at 18:40
