A high pressure steering pipe (that goes from the pump to the rack)
The pas fluid tank
The pipe that goes from the tank to the pump
The low pressure return pipe (that goes from the rack to the fluid cooling pipe on the front cross member - don't need the cooling pipe though)
Also the small valve that sits in the servo pipes near the vac pump that has three pipes connecting to it and one port blanked off.
A throttle body - can be blank with no sensors as I only need the throttle cable bracket from it.
What have you got? Cheers
marksorrento205
- (The other half's wheels)
