Author Subject: Limit the right turn on VTS steering rack?
edhunter
I bought a used steering rack from Xsara VTS. I would like to use it my gti6. The stock steering on 6 has some kind of "limiter" for the right turn. The question is - what part is that I have to use from my original rack to limit the right turn of the vts rack?
Following are service box drawings for GTI6 (left) and VTS racks (right).
Posted 14th Aug 2013 at 11:57
jeffers Forum Admin
Iirc it's the ram that limits the travel. Use the power steering ram off ur 6 rack and you can't go wrong! 99% I'm right but I'm sure someone will be along and correct me if I'm wrong!! LOL
Team Running Engine again!
Team Negative Camber!
Posted 14th Aug 2013 at 12:00
superchargedblack1997gti6
Nope 100% right.
Just use the ram off you're gti6 rack. Job done enjoy a revelation in steering.
Posted 14th Aug 2013 at 12:02
russbez
i want one Sad
My Rallye project thread
Posted 14th Aug 2013 at 12:28
edhunter
Thanks guys Smile
But my technical english is not good enough and I can not understand what you mean by ram - I guess this is part number 10 from left picture - in the service box diagram it is named power steering cylider.
Correct ? Smile
Posted 14th Aug 2013 at 12:37
pretty sure from where I'm looking its part A
Posted 14th Aug 2013 at 12:45
edhunter
yep, part A from vts picture is the analog on part 10 from gti picture
thanks again
Posted 14th Aug 2013 at 12:48
Yes mate that's it use you're original one and the vts rack and you will have much fun!
Posted 14th Aug 2013 at 12:49
Dan has been driving one with a vts ram iirc and has said it seems fine
mik
I've got a VTS rack and fitted the original Rallye ram and it works perfectly. Right hand lock is limited in the normal way.
Cherry Rallye SOLD
Posted 14th Aug 2013 at 17:35
My 6 right turn limiting Ram on top of steering rack was leaking when we removed it ...so I decided to fit VTS Mk1 2.4 rack plus VTS Ram ....I bought off (PUG-306) on here . I kept VTS Ram only because I didn't have a non leaking 6 one ....the tyre (just) catches the corner of the box with 17x40x205 .!!!!
I'm fitting 16x50x205 so a little bit bigger ....nothing to worry about...unless your going to drive at speed on full right lock ?LOL
PS ...if your renewing track rods on a VTS Mk 1 2.4 rack ....6 ones are each 11mm longer than VTS ones ...so buy 6 ones as they fit 100% ...but both inner boots are different ...if yours are cracking so you have to buy VTS ones ....as all ready said track rod ends are same Unsure
Posted 15th May 2015 at 23:50
mik
Didn't know about the different boots, good info thanks.
Cherry Rallye SOLD
Posted 13th May 2014 at 08:01
marco gti6
Day666 and Mik what parts are you referring to as the inner boots on the diagram?
Posted 13th May 2014 at 16:32
I've got all the Citroen & 6 genuine part nos if you want them ?
I've totally refurbed my VTS mk1 rack with all OE bits !!!!
PS ...6 RAM is 10mm shorter than VTS Ram which doesn't limit right lock as 6 one does ....
Posted 13th May 2014 at 21:29
marco gti6
Cheers mate Thumbs up
Posted 13th May 2014 at 21:56
