Author Subject: rallye broken down.
yippeekayay
My rallye has developed a miss fire where it revs clearly without being in gear but as soon as under load it splutters and kangaroos. Car will stall if coasting. Anyone had similar?? starts fine and will run for minutes with no problems but will stall after 5 or 6 minutes or really struggle if driven. Am thinking fuel pump,relay or tps... have all as spares 10 miles away. Any other suggestions???
x box "yippeekayaymofo"
Posted 10th Aug 2013 at 16:13
unplug the lambda, see what happens.
if it was the relay it wouldn't run at all.
Posted 10th Aug 2013 at 16:20
yippeekayay
No difference with lambda disconnected.
Posted 10th Aug 2013 at 16:50
I think I would try the map sensor next
Posted 10th Aug 2013 at 17:05
It sounds like a fuel starvation issue, you should check the fuel pump. Yes
Posted 10th Aug 2013 at 17:27
yippeekayay
Changed pump no difference. Only spare I don't have is a map sensor... so stuck in north wales...how do you test map sensor. Found a great video but no explanation on youtube..
Posted 10th Aug 2013 at 17:32
yippeekayay
Disconnected map sensor and car runs exactly the same so does female logic mean its that???
Posted 10th Aug 2013 at 17:34
yippeekayay
Anyone know how to test map sensor. Cleaned it out with wd ran better for two miles then problem came back ..
Posted 10th Aug 2013 at 18:54
yippeekayay
Now cleaned it out with carb cleaner and runs like a complete bag of crap.
Posted 10th Aug 2013 at 19:20
read the FAQ.
Posted 10th Aug 2013 at 19:30
If you disconnect the MAP sensor whilst the engine is idling it should stall or try to. The fact yours doesn't points to that sensor being the issue.
This would also go along with the fact that the engine doesn't want to rev under load and this could easily be down to the MAP sensor. Yes
Posted 10th Aug 2013 at 19:58
yippeekayay
Yep. Its my deduction. Got two spare map sensors and neither fit. Mines a late phase 2.5 3 by tgd looks. Any one in north wales got a phase 3 sensor???
Posted 10th Aug 2013 at 20:13
I've a ph3 map sensor here. Get on your bicycle Thumbs up
  • Posted 10th Aug 2013 at 21:39
    yippeekayay
    Taa dan. Am soaking it in carb spray and will refit in the morning before she goes home on a aa can in the morning. I have one in coventry but not here.
    Posted 10th Aug 2013 at 22:14
    yippeekayay
    Anyone got a contact number for gwyn rallye???
    Posted 10th Aug 2013 at 22:48
    yippeekayay
    Replacement map sensor has cured the problem. I pretty much called it straight off but wasnt sure. Thanks wp and stan for confirming my thoughts and being at the end of a thread whilst I was at the side of the road. Thanks cos kev fir reminding me of gwyn rallye.... and most of all thanks to gwyn rallye for responding so quickly and generously. Top bloke. Thanks all. I can now join the caravanners going home at 20mph.
    Posted 11th Aug 2013 at 12:19
    No problem, glad it's all sorted Andy. Thumbs up
    Posted 11th Aug 2013 at 15:50
