Author Subject: TICKING ENGINE.
Nose
Hi guys, what actually is it that causes this problem, valves, lifters, rocker arms ? I see it mentioned from time to time , but curious as to what causes it.
cheers
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 9th Aug 2013 at 09:40
Moved to Engines. Smile
The reason has been listed before many a time.
Essentially, there are valves which are ever so slightly bent and therefore the spring strength of the valve spring is strong enough to pull the valve back onto it's seat and create a seal thus the lack of compression loss.
However, this constant 'bending' of the valve eventually weakens it and the head snaps off resulting in severe engine damage or complete failure.
Posted 9th Aug 2013 at 10:09
Does your engine suffer from this then? Dunno
Posted 9th Aug 2013 at 10:10
Tap or tick? Wink
  • Posted 9th Aug 2013 at 10:20
    dangti6 wrote:
    Tap or tick? Wink
    Good point, tapping will be the bent valves as indicated above. Ticking will be loud injectors, not really much can be done about that. I always found the 440cc low boost injectors to be the loudest. Yes
    Posted 9th Aug 2013 at 10:41
    no rockers, lol.
    Posted 9th Aug 2013 at 11:24
    Takedown
    Even from looking at RFS valves they bend...
    Posted 9th Aug 2013 at 12:40
    Roon
    Mine ticks like a cow! Noisy ass injectors!
    Posted 9th Aug 2013 at 13:58
    As I say, it depends on the injector but I've found both the standard injectors and the Bosch 440s are quite loud. Yes
    Posted 9th Aug 2013 at 14:04
