displaying posts 1 to 25 of 37
Author Subject: stop ac turning on
jimmyhackers
despite the only part of my ac system being left is the ac pump and the dash switches.....
it still turns itself on automatically/randomly.........and its miffing me off.
are the ac's functions including this annoying feature controlled by the ecu..... or is there another smaller ecu/controll box that is telling my ac to come on?
if so where is it and how do i disconnect/destroy it?
Posted 7th Aug 2013 at 17:54
you know that button on the dash?
Posted 7th Aug 2013 at 17:58
It will still turn on automatically though.
I have the same.
Posted 7th Aug 2013 at 18:31
Niall
if there is no gas in the system, the compressor wont do anything anyway so just ignore it. Its now no more than just a random Green LED lol
Posted 7th Aug 2013 at 18:55
I think if the ambient temp reads over 25c then the AC will attempt to work automatically. Yes
Posted 7th Aug 2013 at 19:15
aaron6
^^^ what stain said. Smile
Posted 7th Aug 2013 at 19:22
beez_neez_gt
Yep what he said, its more like 21c though on mine.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 7th Aug 2013 at 19:24
mattgti6phase2
Also what Stan said LOL
You can use this to operate your cooling fans now. Pin 1/2 for low speed 1/3 for high speed.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 7th Aug 2013 at 22:53
You can, although be very careful when doing this that the actual compressor has been removed first. If it hasn't, and there is no gas in the system, the compressor will engage as it's been fooled into thinking there is sufficient gas in the system and will subsequently seize which will most likely result in a snapped aux belt and possible damage to the cambelt cover and/or cambelt.
To carry out this mod, the compressor MUST be removed from the scenario first.
Posted 7th Aug 2013 at 23:26
jimmyhackers
thanks for the info so far guys
i ask as i am worried about the compressor functioning, there is definately no gas in the system so it shouldnt be engaging the compressor.
however the other day i noticed the green led was on. i turned it off and and revs picked up a fair bit momentarily as the compressor disengaged, it does this randomly at times :S
is the ambent temp sensor for the ac system accecsable/removable/foolable?
or is this sensor also used for ecu/engine running?
Posted 7th Aug 2013 at 23:35
The ambient temp is picked up from the sensor located in the passenger wing mirror. Yes
Check that somebody hasn't previously bridged the AC pressure switch plug as if there is no gas the compressor definitely should not be starting.
Posted 8th Aug 2013 at 08:13
Just unplug the bloody compressor Laugh my ass off
Posted 8th Aug 2013 at 08:20
You could do this of course, however if there is no gas in the system it shouldn't be engaging, so the question still remains why is it doing so?
Posted 8th Aug 2013 at 08:52
Because its jimmys car...
Posted 8th Aug 2013 at 09:03
Hang on,
This "can't do this fan mod without removing th ecompressor malarky"
Does just unplugging the compressor fix this issue or no?
Its going eventually, Just not yet.
Posted 8th Aug 2013 at 09:21
heliosphan
Interesting point. I hadn't really thought about it but I assume there must be a wiring connection to the compressor to enable it to see the decision of the refrigerant pressure switch and therefore engage or disengage the clutch, as it sees fit?
So, simply disconnecting any wiring input to the compressor should keep the clutch disengaged and spinning freely, allowing you to bridge the connections at the pressure switch to utilise a fan override.
This matter requires urgent clarification and confirmation.
If it turns out to be as simple as this, it'll be the biggest revelation in the history of 306s and will warrant being stickied on the home page. Shock
Posted 8th Aug 2013 at 10:28
yes its that simple.
Posted 8th Aug 2013 at 10:58
mattgti6phase2
It is indeed that simple. Very good mod to keep temps down when battering the f**k out of it LOL
5 x a 306 owner!
Posted 8th Aug 2013 at 11:44
Yes, it's that simple. The compressor gets it power via the loom, however the *signal* which is sent via this loom comes from the pressure switch. Therefore as long as the correct pins on the pressure switch plug get power, it will allow power to be sent to the compressor. Yes
So yes, unplugging the compressor will of course stop the compressor from engaging as it will have no power.
The reason I always explain to people that want to try this mod is to make sure there is no compressor present first is because some people won't have the thought of unplugging it and would end up with damage occuring.
Posted 8th Aug 2013 at 13:58
IS the plug for the compessor simple to find?
I'll have a go later.
Dont fancy that cambelt damage no matter how slim
Posted 8th Aug 2013 at 16:13
Yep, a white plug which fits on top of the compressor. Yes
Posted 8th Aug 2013 at 19:22
Locate the compressor, follow the very short wire and BINGO! A plug will be on the end of it. It really is that simple.
  • Posted 8th Aug 2013 at 19:44
    aaron6
    Somewhere there were photos of this trick. I.e how you wire up the switch. Might be good to get a faq sorted if someone has time. Smile
    Posted 8th Aug 2013 at 19:55
    It's not hard - bridging pins 1 and 3 gives you low speed fan operation, bridging pins 1 and 2 gives you high speed fan operation. Yes
    Posted 8th Aug 2013 at 22:48
    There's a few threads about it with instructions.
  • Posted 8th Aug 2013 at 23:00
