Author Subject: Removing RFS pistons from rods
JWP EFi
Turbo Legend!
Just wondering how others are doing this. i made up a semi circle hardwood (so will not damage the piston) jig with a hole for the gudgeon pin to pass through. Easiest way ive found is to gently heat the small end with oxy then carefully press the pin out. A couple of engineers told me to put the assembly in boiling water or even hot oil prior to pressing, this didn't really help.
Posted 6th Aug 2013 at 21:13
you need to get the rod VERY hot, but not the pin.
If you do need to remove them I doubt you will be re-used however, so its no big deal to just press the pins out with a press cold.
Posted 6th Aug 2013 at 21:21
JWP EFi
Turbo Legend!
its a balance of heating the rod so it expands enough but not to the point where the pin wants to expand. I practiced on a scrap piston/rod in a cold press, took a fair bit of pressure then the piston broke
Mine will be reused, I'm dreading refitting them!
Posted 6th Aug 2013 at 21:25
why are you removing them?
Posted 6th Aug 2013 at 21:34
JWP EFi
Turbo Legend!
to get them pocketed. and before you say they can be done with the rod still attached, a friend of a friend will pocket them in exchanged for beer tokens providing i give him a set of bare pistons. This guy has mod'd many a piston for a variety of different engines so i trust he will be more than capable.
Posted 6th Aug 2013 at 21:39
sod removing them, just get him to do them in situ, far too high a risk of damaging them.
Posted 6th Aug 2013 at 21:45
JWP EFi
Turbo Legend!
i do agree with what your saying but his preferred method is to do them this way. If i want him to split the assembly then labour costs will rise somewhat.
The more i think about, the £110 i was recently quoted by Bridgecraft does seem very fair, but i do like to do as much as possible myself, not just for cost issues
Posted 6th Aug 2013 at 21:49
Does he realise the damage risk and how the rfs pistons are fitted?
Also does he know the inclination of the valves and how much can be taken off safely?
I really would get someone that knows the rfs to do them.
Youll look a right dick if you get a freebie only to damage them and need more done Wink
Posted 6th Aug 2013 at 22:05
24seven
As above, even heating the rods up alone can potentially weaken them in that localised area.
Posted 6th Aug 2013 at 22:11
JWP EFi
Turbo Legend!
fair play fellas.
Posted 6th Aug 2013 at 22:27
This is definitely worth thinking about, Mei has some good points here. Yes
Posted 6th Aug 2013 at 23:29
jeffers Forum Admin
Personally having had my pistons pocketed by bridge craft not so long ago, I'm inclined to agree with Stan and mei. If there's any mistakes made in machining then your whole engine build could be ruined, for the sake of £110 get it done by Martin and rest in the knowledge it's been done right.... Just my 2p's worth! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 6th Aug 2013 at 23:44
allanallen
We leave them on the rods for a reason Wink
Facebook
Posted 7th Aug 2013 at 05:35
JWP EFi
Turbo Legend!
I agree too. I spoke to the chap who is/was going to pocket my pistons and he told me its easy enough to remove the pin however sometimes the rod can end up being scored as a result of the very tight clearance so, Bridgecraft it will be.
Posted 7th Aug 2013 at 21:09
I think you are making a wise choice with that decision. Smile
Posted 7th Aug 2013 at 23:22
oldbrownshoe
Who is mei ?
French military victories?
Did you mean French military defeats?
Posted 16th Aug 2013 at 23:35
smegal
oldbrownshoe wrote:
Who is mei ?
Welshpug
Ex SC-6
Now in a Megane R26
Posted 16th Aug 2013 at 23:47
