Author Subject: I've used the search box but. ..
mr west
Still can't really find what I'm after.
Has anyone used bike bodies/carbs other than yanni? If so id be interested to see the results and how you set them up regards to management, fuel rail. Etc
Thanks
white rallye
cherry dead rallye
s16
Posted 6th Aug 2013 at 15:47
I've GSXR bike bodies on a satchell inlet etc. Managed by a DTA S40.
  • Posted 6th Aug 2013 at 15:51
    setup - aftermarket management is the typical route, but as jammapic recently posted sorting the MM 1ap10 can be mapped.
    fuel rail depends if the original inlet is used as a donor or not, but generally a pico style injector is used in the bike bodies, you'd need a separate FPR for this, just a fixed 3 or 3.5 bar is enough, no need for an adjustable unit, they are unreliable too.
    many of the satchell engineering setups used by sandy brown utilise bike bodies, have a look on facebook.
    Posted 6th Aug 2013 at 15:56
    mr west
    Yeah jammapics thread is an interesting read. Ideally I would like to stay on standard ecu for cost saving. And what bike bodies are the best choice. Im fairly handy so would make my own manifold. But im a bit hopeless with wires. Very interested to see what people have done.
    white rallye
    cherry dead rallye
    s16
    Posted 6th Aug 2013 at 16:03
    The satchell manifolds aren't actually bad value for money - especially with the development that went in to them to get the correct length and angles etc.
  • Posted 6th Aug 2013 at 16:06
    mr west
    What's he charge for them Dan? Are they gsxr 1000 or 600 and what year. EBay is a bit of a mind field
    white rallye
    cherry dead rallye
    s16
    Posted 6th Aug 2013 at 16:09
    1000 and 750 use the same bodies over most years, I think K3 to K4 are preferable, however I would speak to them first as they may not be doing them other than for special projects, the manifolds theyve been doing recently for 16v XU's have been DCOE pattern, which are about £180, so comparable to the price of a Jenvey, then you'd just get DCOE type Jenveys (not the linkage type) trumpets fuel rails and an FPR.
    Posted 6th Aug 2013 at 16:40
    mr west
    Ah ha, thanks welshy. Was thinking of making a manifold out of the standard one to get betting lengths than jenvey. The real problem is where to get the standard ecu mapped as im about four hours from mr schofield
    white rallye
    cherry dead rallye
    s16
    Posted 6th Aug 2013 at 16:46
    not far at all in reality then, many good mappers and engine builders have people coming from overseas!
    Posted 6th Aug 2013 at 19:43
    mr west
    This is quite true , I was just thinking lazy. . I would trailer it that far unmapped though .
    white rallye
    cherry dead rallye
    s16
    Posted 6th Aug 2013 at 19:48
