Author Subject: SOLD Saftey devices 6 point roll cage
Up for sale is my saftey devices roll cage ? It's the 6 point bolt version and was part of the last group buy done by Rich W and had the harness bars welded in at extra cost
It's only been installed in my rallye but barley used winced installed - I have returned car to normal now so it's for sale. Comes with all mounting plates door bars etc , no welding required
Ill get some better pics once it stops raining but as you can see its like new
I can help install it if required and I'd rather not split
£550 Ono
Posted 7th Aug 2013 at 18:43
soton_s16
How does it fit if there is no welding required?
As the last bolt in cage I had for my 205 I had to get the plates welded under my car for the bolts to bolt into (if that makes sense...)
For all your Peugeot needs PugRacing.com
Gti S16 199bhp 164 ft lbs torques!
Posted 5th Aug 2013 at 19:29
The legs to the cage go directly onto the floor and the plates sit under the car you bolt through all three making a sandwich of the car ? No welding is required unless you want to weld the plates once they are bolted into place ?
The plates are just flat bits of steel with holes in them ? No threaded parts or anything like that Thumbs up
Posted 5th Aug 2013 at 19:34
plates always need welding.
Posted 5th Aug 2013 at 19:54
They are not inside the car they are underneath the car not sure how you would weld them ? But seeing as you are the oracle on everything ?Razz
Posted 5th Aug 2013 at 20:13
Depends what your using it for I would say.
But not much point in buying a bolt in cage if it needs plates welding to carDunno granted welded anchor plates will be better/strongerThumbs up
Posted 5th Aug 2013 at 20:25
It's not like an omp cage that needs mounting points welded in. It's literally a bolt in cage Thumbs up
Posted 5th Aug 2013 at 21:26
Tallguy_2
Does it stitch into the a and b pillars or top of the screen Chris?
"winners come and go but legends never die..."
autorite-sport.co.uk
Posted 5th Aug 2013 at 21:39
Nope no mounting points other than the 6 on the floor
Posted 5th Aug 2013 at 21:49
Tallguy_2
Ok mate
Posted 5th Aug 2013 at 22:27
Sold
