displaying posts 1 to 25 of 33
Author Subject: Another Efi Euro 1 ecu & loom
gti6girl
This is off my old rallye
Efi euro 1 ecu and loom to suite gti6 on bodies
There are a few people to map this. You have Richard longman in the new forest. Brumster on here has the knowledge and has done car before.
You also have track&road in Essex who are excellent at mapping.
If your not interested in buying please do not post
£300 delivered
Thanks
Posted 1st Aug 2013 at 17:15
gti6girl
Now comes with touring car lightweight pully and 4+1 pickup which is already setup on this ecu
This makes the engine fire up on the button
Posted 28th Aug 2013 at 20:52
How does that work / attach dude ?
Posted 28th Aug 2013 at 20:54
crank bolt.
Posted 28th Aug 2013 at 21:00
gti6girl
Yep just straight on same as standard
Posted 28th Aug 2013 at 21:01
crank bolt.
Instead of the standard crank pulley ?
Posted 28th Aug 2013 at 21:02
gti6girl
Yes
Posted 28th Aug 2013 at 21:04
Im lost ?
Where does the sensor go ?
Posted 28th Aug 2013 at 21:08
gti6girl
There is a thread in the sump it bolts to.
Posted 28th Aug 2013 at 21:14
on the standard alloy plate next to the pulley.
bit like this
Posted 28th Aug 2013 at 21:18
So you ditch the TPS on the side of the bodies then ?
Posted 28th Aug 2013 at 21:19
gti6girl
It gos where a normal crank pully gos with the sensor right next to it so you do away with the standard TDC sensor in the gearbox
Posted 28th Aug 2013 at 21:22
JWP EFi
Turbo Legend!
A friend of mine uses this exact same setup on his 205 gti6 turbo running cosworth management, works fine. Btw did you have to trim the bottom timing cover at all?
Posted 28th Aug 2013 at 21:35
gti6girl
No it fits straight on
Posted 28th Aug 2013 at 21:42
JWP EFi
Turbo Legend!
what diameter is the rib pulley?
Posted 28th Aug 2013 at 21:44
gti6girl
Would need to measure tomorrow
Posted 28th Aug 2013 at 21:46
Ah I see its a trigger wheel then
Posted 28th Aug 2013 at 21:53
JWP EFi
Turbo Legend!
thats the one mate. although i'm trying to figure out why you would want to do it this way as the euro can read the standard 60-2. im guessing that a super light flywheel was used therefore not having any counting teeth for the crank sensor
Posted 28th Aug 2013 at 22:00
I think it's just easier to start with this rather than the standard tdc ?
Posted 28th Aug 2013 at 22:05
not really but the ecu doesn't do 60-2 i think?
Posted 28th Aug 2013 at 22:07
JWP EFi
Turbo Legend!
hmm, i know when my mate did his 205 he went through lots of trial and error getting one of the teeth to line up with the sensor when at TDC, he had no option though as his ecu could ONLY use the 4 tooth trigger. also had to modify the brake vacuum pump to create a 2 tooth trigger for the phase sensor which was a totally different story
Posted 28th Aug 2013 at 22:10
JWP EFi
Turbo Legend!
the Euro 100% does do 60-2. mine had this as do a most peugeots running this ecu
Posted 28th Aug 2013 at 22:11
pete_rallye
Indeed, the one I sold to gti6 girl was setup to run from 60-2. The main issue with them is getting into them to program them as most seem to be locked, and the comms cable efi sell that you need to program it is daft money.
As long as you fit the TDC sensor in the right position, with the trigger disc that nick is selling it will run fine.
It didn't use a cam sensor too did it?
Lap of the 'ring
Posted 28th Aug 2013 at 22:31
JWP EFi
Turbo Legend!
mine didn't, i was referring to my friend's car which runs cosworth weber-pectel management.
I think my old euro was the one you sold to gti6girl.
also i believe i have the code which allows you to access the ecu and the interface which costs ~700 from OBR
Posted 28th Aug 2013 at 22:47
gti6girl
Pete did not sell me the efi. I've owned mine for about 8years, I just purchased the pully off Pete
The reason for this pully is for the weight saving and the added bonus of having the engine fire straight up and not having to go through the 4 cycles or what ever it does
The bracket can only go in one position so it you did not have this bracket it would be a nightmare to set up I believe
Posted 28th Aug 2013 at 23:08
