displaying posts 51 to 72 of 72
Pages (3): 1 2 [3]
Author Subject: Difficulty starting car
Post #51
I always fill the rad up then start the car and bleed it whilst it's running using the three points.
I've never made a header tank for doing this on these engines, yours should be fine but I personally wouldn't have done it the way you did.
Posted 25th Aug 2013 at 18:58
RetroPug
Post #52
Hmm was following the FAQ...
Also, the coolant was absolutely crystal clear, apart from the bolt in the heater matrix bleed point was covered in oil/black liquid. The bucket of coolant which drained out looked normal though.
I'll borrow another car to go to work tomorrow and check to see if it bled properly tomorrow afternoon.
The header tank was working fine until it suddenly spat 110 degree fluid everywhere! Glad it didn't get me in the face, wasn't far off!
Posted 25th Aug 2013 at 21:04
RetroPug
Post #53
Car didn't want to start from cold at all yesterday, took ages to get going, but when hot it started no problem.
Going to attempt to re-bleed the cooling system to see if that helps. Strange that it was fine since replacing the sensor and bleeding the system up until now.
Posted 4th Sep 2013 at 09:19
RetroPug
Post #54
Re-bled it. When the thermostat opens (I assume), the coolant level rose like last time and began overflowing out of the rad so I quickly got the cap on. I'm really not sure this is normal? I'd have expected it to go down if anything when it began circulating...
Posted 4th Sep 2013 at 16:49
RetroPug
Post #55
Bleeding the system properly appears to have stopped upsetting the new CTS. Thank you everyone.
Posted 9th Sep 2013 at 09:01
RetroPug
Post #56
The car is extremely reluctant to start from cold again. Not always, only sometimes, and only when cold. It has been fine for a while since replacing the CTS and bleeding the coolant system properly....any ideas?
Posted 17th Sep 2013 at 11:03
dcc
Post #57
headgasket.
205 GTI
Xsara HDI
Posted 17th Sep 2013 at 11:26
RetroPug
Post #58
As I have been fearing...the car runs flawlessly though.
I know a few members do HG replacements...anyone willing to travel to Oxford and do one if this is the case?
Are there any checks I can do? No bubbling in coolant at idle, no mayo around oil filler or rad cap, car has been having difficulty cold starting for a fair while without having total HG failure...
Not sure what to do tbh.
Posted 17th Sep 2013 at 11:36
dcc
Post #59
Check the colour of the plugs.
205 GTI
Xsara HDI
Posted 17th Sep 2013 at 12:10
RetroPug
Post #60
Ok will do ASAP. Thanks.
Posted 17th Sep 2013 at 13:13
RetroPug
Post #61
Actually thinking about it, when the car got up to temperature and I assume the thermostat opened, there were A LOT of bubbles coming through and the coolant was rising very fast, could this be an indicator that combustion gases are getting into the coolant?
Posted 17th Sep 2013 at 13:23
jimmyhackers
Post #62
try your fuel pump. mine had exactly the same problem. reluctance to start etc but once going it seemed to run generally fine (sometimes cut out under breaking and had to cure with ecu reset under electrical load).
boshed in another one with good pressure and everythign was A-OK. idles dead on, not even the slightest hint of random tiny hunting i had before.
bit pricey new but worth it.
Posted 19th Sep 2013 at 01:26
jimmyhackers
Post #63
and my theory on why so... low fuel pressure will cause a poor spray pattern. the fuel is not properly atomised because of this. on cold starts there is no internal engine heat to boil this into a finer atomised mist. hence trouble starting
but once the engine is warm. on starts the heat of the engine inside the combustion chamber masks the low fuel pressure problem by alowing the fuel to atmoise properly.
Posted 19th Sep 2013 at 01:34
dcc
Post #64
Err, no.
205 GTI
Xsara HDI
Posted 19th Sep 2013 at 06:13
RetroPug
Post #65
Haven't had the chance to check plugs yet, coilpack bolts were rounded off by whoever last serviced it.
They are M6 capheads, anyone happen to know the length to save me pulling one out so that I can buy a set of good ones?
Posted 20th Sep 2013 at 16:21
Post #66
20mm I believe. Yes
Posted 20th Sep 2013 at 17:07
RetroPug
Post #67
Thanks mate I'll get a few.
Posted 21st Sep 2013 at 14:41
RetroPug
Post #68
Changed the plugs for new NGK ones. The car ran fine with the new plugs but was slightly high idle (just over 1000rpm instead of 950ish) and still had a bit of difficulty starting from cold.
Here is a picture of the old plugs. I have used the car fairly regularly for a year, but before that it was only used in summers and these plugs were what were in there so that may affect the colouring? Please me what you think. Could this be the HG?
Tomorrow I might check the ICV with a multimeter, I did clean it a while back with no issues but it is worth a check.
RetroPug has attached the following image:
Posted 27th Sep 2013 at 19:04
Post #69
Those plugs look a lovely colour to me. Yes
The threads are a bit oily by the looks of it, but the actual colour of the plug says good to me. Smile
Posted 27th Sep 2013 at 19:08
RetroPug
Post #70
Thank you for your input.
Any ideas as to what the problem might be? Anything other than the ICV to check? Seems like the most likely thing given that it seems to struggle for air on start and throttle helps it choke into life, and it occasionally idles ever so slightly rough all of a sudden.
CTS fixed the issue for a short while so maybe both CTS and ICV were going funny...
Posted 27th Sep 2013 at 19:35
RetroPug
Post #71
Also...testing the ICV with a multimeter...test both pins of the connector? Not sure exactly where to test, bit clueless about electronics.
Posted 28th Sep 2013 at 10:41
RetroPug
Post #72
Bump, anybody know the correct way to test the ICV with a multimeter?
Posted 1st Oct 2013 at 12:08
Pages (3): 1 2 [3]
