| Author | Subject: Difficulty starting car |
RetroPug
Bump: Assuming I need to flush coolant to do it? Or is it even simpler than that?________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
stan_306gti6
Yes, that is the correct part number. ![]() As for changing it, just unscrew and replace, it's that simple. You *may* need to bleed the cooling system after doing this, but you may get away with not doing this. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
RetroPug
Perfect, thank you. Picking it up on the way home and doing it at the weekend.I will bleed the cooling system as I'm not 100% sure the garage who last had the car did it properly. Is it okay to bleed by topping up with different coolant to what's in there already? (No idea what that is), or do I need to flush and re-fill? Radiator is brand new, couple of month-old nissens so won't be gunked up etc. and coolant already in there is nearly new. Thanks for all the help so far! ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
If you do it while the system is cold and not pressurised you will loose very little coolant.________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
RetroPug
Okay. ![]() I'm going to bleed the system anyway though as I'm not sure it's been done properly as is. Obviously that involves topping up with more coolant, I'm just checking that I shouldn't get issues mixing different coolants...wouldn't have thought so. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
RetroPug
Update:After swapping sensors, the car started first time. Fingers crossed that it does the same in the morning. However, when removing the sensor there was pressure built up in there. Is this a bad sign, like pressure being built up in the rad? The car has not been driven since yesterday morning. There are also some crusty stuff on the old sensor, It's dry and crusty, which I'd imagine is old, dried out crust from coolant, and not the "mayo" you associate with HG problems? Thank you for the help so far.7 Picture of old CT sensor attached. RetroPug has attached the following image: ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
stan_306gti6
Glad you managed to get it done successfully. I suspect the slight pressure may be air still in the system as you suspected it hadn't been bled properly before. Now you have bled it properly, it should be ok. That sensor does look cruddy though, perhaps the whole system could benefit from a coolant flush, and get out any other bits of crud. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
RetroPug
I have not yet bled it.The coolant in it is brand new as it was replaced when the radiator was changed, but the previous owner used it as a summer-only car so it sat all winter every winter so congealed coolant is not much of a surprise... Flushing is usually achieved by draining and then forcing water through with a hose? I might do this next weekend and fill it all up properly, bleeding it and see whether or not I get pressure. Doing other service bits next weekend anyway! ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
stan_306gti6
Yeah, ideally whip the thermostat out after you've drained the rad and then force water through the entire cooling system including the rad and then remove the top hose from the rad and force water through the hose and through the block. ![]() This will clean it out well. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
RetroPug
Post #35
Thank you!Yeah I'll do this next weekend. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
RetroPug
Post #36
What sort of coolant mixture do people normally use?Follow instructions on coolant? Pure coolant, a mixture of coolant and de-ionised water? To fill up and properly bleed a full system I'm looking at around 7L of fluid from memory? At work so I don't have time to browse the forum sorry! Wanting to buy coolant on the way home. Thank you! ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
rikky
Post #37
coolant is designed to be mixed with water, and won't provide the right efficiency using it in undiluted formi've always used a 50/50 mix for everything ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
RetroPug
stan_306gti6
Post #39
It's around 6 litres in all I believe, I normally buy 5 litres of pure coolant and use around 3 litres, then use water for the rest. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Post #40
Its 7.6 litres, so Stan's coolant mix is a bit weak.Check the bottle however, as they always give percentages to mix for specific minimum temperatures. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
Post #41
welshpug! wrote: Its 7.6 litres, so Stan's coolant mix is a bit weak. Check the bottle however, as they always give percentages to mix for specific minimum temperatures. Yeah I guess, although my car doesn't get used in the winter and does get stored in a warm environment. Plus it gets coolant changes very frequently when it is being used. ![]() I guess as an everyday car, used all year round you would need a stronger coolant mix to be on the safe side. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Post #42
you need to use a stronger mix in the summer to prevent corrosion ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
Post #43
No corrosion here thanks, I keep the system in perfect condition, as I say I change the coolant extremely often. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
RetroPug
Post #44
Yeah I've had a look at the bottle, got 5L of coolant and 5L of de-ionised (they call it de-mineralised here) water, so I'm safe.Started doing everything but I've got to pop out now unexpectedly so I guess I'll return to it later. Thanks everyone. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
RetroPug
Post #45
Does the thermostat slide straight out? I've removed the plastic 90deg elbow and all of the bolts & bleed screw (a lot of pressure built up in there even after rad. pressure was released).I've unplugged the sensors but not removed them, it's currently chucking it down with rain so I will go and continue trying to get it out if/when it clears. If it won't come out I guess I'll try removing sensors but I'm not sure this is necessary? Not that it is difficult anyway. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
Post #46
You dont touch the bolts or sensors, only the plastic elbow.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
RetroPug
Post #47
I'm trying to be able to flush water through the block. The thermostat slides out without removing the housing?Still chucking it down so will continue trying a bit later. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
Post #48
Yup, probablt stuck in the rubber seal, give it a good yank.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
RetroPug
Post #49
I've got a bit of a history of yanking on things that should come straight ou and breaking them so just wanted to be 100% sure!Your help is very much appreciated, thank you! ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
RetroPug
Post #50
Right...followed the guide in the FAQ to the letter. Made a header tank, no coolant escaping, opened the three bleed points... filled up, coolant came out of them in the right order and I closed them. I then started the car, let it get up to temperature, revved the engine a little bit occasionally and got bubbles coming through. Car got up past 90deg. on the gauge with no problems, still getting the odd bubble coming out, particularly when I revved a bit by hand. It got to the point where no bubbles were really coming out anymore, I went round to check the temperature; around 105ish. The whole engine suddenly shook and the "header tank" burst off and coolant started pouring out of the radiator very quickly. I managed to use a towel and stick the radiator cap on. I don't understand what happened or why? There were no bubbles when it was spewing out. I also now have no idea whether or not the system is air-free. I started the car again after I cleaned everything up and it started and idled fine. I will let it cool and check to see if the coolant is pressurised in 3-4 hours. Anyone had this happen before? Did I do something wrong? ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
