displaying posts 76 to 83 of 83
Pages (4): first .. 2 3 [4]
Author Subject: Mapping Throttle Bodies on Standard Management - Chip Wizards!
mr west
Post #76
O really. Thanks I will do when I have some parts together. No point till then really
white rallye
cherry dead rallye
s16
Posted 5th Aug 2013 at 15:59
russbez
Post #77
took me a few days but that's me booked in with Mr Schofield for the end of the month Yes
My Rallye project thread
Posted 5th Aug 2013 at 16:10
jammapic
Post #78
Cool.. What work? Just a tweak of the mapping on the supercharged motor?
Drop me a message with when your going and I'll fly across to say hello! (he's not far from me!)
JP
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 5th Aug 2013 at 16:36
russbez
Post #79
yes high boost custom map
i really wont be there very long mate, i am dropping the car off and then i am off pretty much straight away ill try and mind pm
Posted 5th Aug 2013 at 16:55
Post #80
I'd be interested to see the result Russ. Yes
Posted 5th Aug 2013 at 19:05
jammapic
Post #81
OK, so backtrack a tad...
I talked about using staggered trumpets to move harmonics in the torque curve, and make for a smoother power band and more area under the curve.
But, they say the proof of the pudding is in the eating, so here it is.
Here, you can see two dyno plots overlaid. The one which makes peak power at slightly higher RPM is with the shorter trumpets, and the one with power at lower RPM are the longer trumpets.
You can see the shape of the curves are identical, but higher and lower RPM peak power. This is normal for longer and shorter trumpets. This is the key here.
When we have two of the trumpets long, and two short, we effectly find a "middle ground" in the curves. This is helpful as we fill the troughs with power, but we do also lose our peaks - hence the peak power is marginally lower.
What's important though, is area under the curve. Clearly, the more the better, and by filling the troughs we make the car smoother and more drivable.
Below is the outcome of the staggered trumpets:
We actually did find a little more power with some more ignition advance and leaning the mixture out a touch, but the shape of the graph remained largely the same.
Posted 21st May 2014 at 20:08
Hawkesfire
Post #82
Great guy really worth every hour of trying to track him down for an appointment and worth every pennie for the mapping as he got my SHB rallycross car flying with loads of power.
Marty
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 7th Jun 2014 at 18:20
tom_g205
Post #83
The staggered trumpets is an intresteting one. May I ask, how much are they staggered by and which ones as in 1 and 4 long 2 and 3 short?? And lengths??
Cheers Tom
205 GTi-6 every day motor
205 GTi-6 weekend/track car - project 230 N/A fingers crossed.
Posted 13th Jun 2014 at 13:44
