displaying posts 51 to 75 of 83
Pages (4): first .. 2 [3] 4
Author Subject: Mapping Throttle Bodies on Standard Management - Chip Wizards!
jammapic
Post #51
Forward planning really, and just to beef it up a bit. Engines I've played with in the past have always either picked up a bottom end bearing, or snapped rod bolts. Prevention is cheaper than the cure!
JP
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 31st Jul 2013 at 19:21
allanallen
Post #52
coskev wrote:
its a rolling road, therefore an educated quesstimate at best, a wild stab in the dark at worst!
So what do the tuning gods use to record bhp?Dunno
Race results! Which mr schofield has too Smile
I had the pie and chips last time I went, was superb Razz
Facebook
Posted 31st Jul 2013 at 20:20
Post #53
tuning gods aren't interested in the numbers, they're interested in the curve, and of course the results, and on top of that if they actually are half decent, reliability.
Posted 31st Jul 2013 at 20:25
Post #54
fook me, just read the spec, DE ADVANCE THE CAMS IMMEADIATELY!!!!
Posted 31st Jul 2013 at 20:30
jammapic
Post #55
Why so? Seems to make good power and no valve piston contact... It's only a couple of degrees as well tbh.
JP
Posted 31st Jul 2013 at 20:38
jammapic
Post #56
Also, had them like that for about 2000 miles, Wayne didn't even need to touch them as they were making good power.
JP
Posted 31st Jul 2013 at 20:55
Post #57
Curve looks good to me.
Posted 31st Jul 2013 at 21:19
mr west
Post #58
jammapic wrote:
Ok:
Long life 2.5" exhaust, 200cell sports cat
Head gasket done by cg cars
Bosch plugs
Lightweight pulleys
Air con delete
ARP rod bolts
Big end bearings
Jenvey 45's on Longmans manifolds
Open 60mm trumpets
Fuel pressure reg set at 3.5bar
Advanced cam timing
Chip Wizards mapping
That's about it for the engine side of things I think.
hmm, what did you do with the throttle position sensor etc, would love to see some good pics of how it looks under there.Thumbs up
white rallye
cherry dead rallye
s16
Posted 31st Jul 2013 at 22:38
jammapic
Post #59
Just wired a superseal plug onto the loom on the bodies and car. Plugged straight up and mapped!
Posted 31st Jul 2013 at 22:56
mr west
Post #60
Did you use the jenvey linkages. This is all very interesting
white rallye
cherry dead rallye
s16
Posted 31st Jul 2013 at 23:38
Post #61
If your happy with it ....fair play .!!!!
Your the one that counts Thumbs up
Posted 31st Jul 2013 at 23:54
gilesy
Post #62
This reminded me of Jeff Goldblum in Independence Day LOL
Posted 1st Aug 2013 at 00:12
jammapic
Post #63
OK... so you wanted to see how it looks under the bonnet... A battered set of Jenveys and my pikey wiring:
and my filters which lose me 8hp! lol
JP
Posted 2nd Aug 2013 at 13:03
blandy
Post #64
What's the thoughts behind the cam timing change? As been said most only hit around 180bhp with a similar set up and only break 200 with cams so whatever youve done must have a hige effect as guessing his rollers are regrded as fairly acurate if he does the charger maps etc..
I had similar filters on mine and was warned off them by the mappers after they had a car suck in a individual sock type filter lol I think that's the main reason against them type as the other filters are mesh backed so prevent this.
Posted 2nd Aug 2013 at 13:16
jammapic
Post #65
Can't say how accurate the dyno is, but seeing the car with exhaust, sports cat, k&n filter and timing tweaks ran 177hp i'd say it's probably there or there abouts, maybe a couple of hp over - but certainly not excessive.
I've just been out for a hoon in the car now, and it's running great. Sounds excellent...
I agree, these filters are crap. I've got a Pipercross sausage filter to sick on at some point, but I need to move the PAS pump.
JP
Posted 2nd Aug 2013 at 13:19
Post #66
I take it that you will be removing that pressure gauge soon, as I doubt a footpump gauge is designed to have fuel running though it LOL
Would be interesting for you to get hold of a Satchell DCOE inlet and do a back to back, as they are known to give much better midrange as well as a significant peak increase over the Jenvey inlet, guarantee a true 200 Razz
might not need to move the pas pump with the Longer inlet either.
Posted 2nd Aug 2013 at 13:39
jammapic
Post #67
I have seen those before welshpug, but only every attached to bodies etc - so hard to get hold of.
Yes, the gauge is coming out next time I lift the bonnet - just waiting for a blanking plug to turn up.
Truth be told, the inlet length isnt long enough for peak performance really, I was going to put longer trumpets on it as I'm getting some pretty bad reversion / fuel standoff and you can see from the dyno plots it goes a bit wobbly!
JP
Posted 2nd Aug 2013 at 13:41
Post #68
no I meant the more recent ones, made from a donor gti6 inlet, I think miles may stock them, but I got mine made by Satchell engineering direct, they cost the same as a jenvey inlet!
trumpet shape has a fair bearing on how they behave too, I think from talking to sandy the longer jenveys aren't ideal, hence sandy usually using ones that colin makes which have a tighter radius, not too dissimilar to the short ones you already have as it happens.
Posted 2nd Aug 2013 at 14:24
jammapic
Post #69
Ok, useful to know.
So you think a set of the longer manifolds matched with the setup I already have should pick up some midrange and a few peak hp?
JP
Posted 2nd Aug 2013 at 14:46
Post #70
from miles's reports and the results Sandy and a few of the 205ers running satchell/brown setups definitely.
http://forum.205gtidrivers.com/index.php?showtopic=105821&page=24
blue line is Kev's engine, yellow is kate's.
the main one that highlights the difference is the torque, the dark blue line hump tracking about 10-30 lbft more than the purple line
kev has satchell inlet, kate has shorter one, kev has milder cams, longer exhaust manifold.
figures at the wheels btw, though not a calibrated RR, both around 185 ish peak at 6750 from 1.9 MI16's, but there's no doubt at all that kev's will be quite a bit quicker.
Posted 2nd Aug 2013 at 14:57
jammapic
Post #71
Jeepers, thats a fair old gain right there... Some more midrange would be great tbh.
JP
Posted 2nd Aug 2013 at 15:15
mr west
Post #72
Great thread. I'll be looking out for second hand jenvey now. And might make my own manifold from a standard one. Wonder if any one else can/will map the standard ecu for this set up. As I live near Cambridge Wayne is a fair old treck from me
white rallye
cherry dead rallye
s16
Posted 5th Aug 2013 at 14:35
mr west
Post #73
white rallye
cherry dead rallye
s16
Posted 5th Aug 2013 at 14:50
jammapic
Post #74
I know he sometimes does work down your way... If I were you, I'd give him a ring and ask!
JP
Posted 5th Aug 2013 at 14:53
mr west
Post #75
O really. Thanks I will do when I have some parts together. No point till then really
white rallye
cherry dead rallye
s16
Posted 5th Aug 2013 at 14:57
