Author Subject: what bits do i need?
drewhughes
hey just bought a 2nd hand cat back exhaust including a devil decat.
what gaskets/parts/bolts do i need?
part numbers, or kits? will be of help
Drew
Posted 27th Jul 2013 at 17:05
What system is it ?
May get away with just re using what ever is the car or may need a cat fitting kit a 2 exhaust clamps ?
Posted 27th Jul 2013 at 17:17
jimmyhackers
35mm exhaust clamps. can get em from anywhere. 2 or 3 needed. i would double check though. they might be a slighly wider pipe? set of vernioer calipers will tell you. or a set square and a ruler.
if you redoing the manifold to cat section, id highly reconmend a new set of sprung bolts and the large crush washer, you can get the kit from car spares or pug or ebay etc, bout a tenner for the lot. every pug ive had has mad a mangled crush washer that leaks.
Posted 27th Jul 2013 at 18:20
jimmyhackers
oh and some gun gun/exhaust paste. make sure where your applying it is shiny metall (wire brushed) otherwise it wont adhere. use lots and clean up the excess afterwards.
also while this is setting (car engine idling to heat up exhaust for 30 mins or so) resist the urge to press the throttle, the excess pressure could blow out the paste before its set and you have a leaky exhaust.
hope this helps
Posted 27th Jul 2013 at 18:22
