Author Subject: Here is my new car (205 GTI6)
gjuk
There are a number of things that need doing, I hope you can help point out some 'mistakes' or things that need sorting in the engine bay for me. Do not know much about these cars/engines.
Jon
Posted 25th Jul 2013 at 20:30
that red sleeving is your speedo cable, tie it back away from the manifold asap, and make sure it is plugged into the speedo drive unit which is on the right hand side of the diff casing, where the right hand long driveshaft enters.
Posted 25th Jul 2013 at 20:36
allanallen
No offence but but that's an awful conversion
Facebook
Posted 25th Jul 2013 at 20:43
Citroen Xsara VTS lump.
Is the positive terminal secure with that bracket underneath the red screw cap??
  • Posted 25th Jul 2013 at 20:47
    gjuk
    None taken Smile I didnt do it! It was cheap however.
    Why do you say this however, sure it needs a tidy but it looks okay to me.
    Posted 25th Jul 2013 at 20:53
    gjuk
    VTS lump, different from a GTI6 lump?
    Posted 25th Jul 2013 at 20:54
    allanallen
    Things jumping out at me are the fuel pipes looked to be rubber hose jubilee'd over cut plastic pipe, not ideal for 7bar of fuel pressure.
    Top rad hose looks like an accident waiting to happen, speedo cable on manifold, gaffer tape covering the hacked up hole in the cambelt cover for m/c clearance, purge canister still present and w**king about, zip tied on ecu box, bare wires to coil (incidentally the ones added in are probably for the tacho). These are just the easily spotted things, you've certainly got your work cut out but if it was cheap fair play.
    Vts and gti6 engines are nigh on identical, not even worth mentioning to be honest
    Facebook
    Posted 25th Jul 2013 at 21:06
    gjuk
    Thank you!
    I am grateful for your comments.
    I tied that ecu up, I was trying to clean the bay up and it needs to find a full time home in the bay.
    Agreed, it has been done on the cheap. It has semi slick yoko's though, worth £400 and GTI brakes.
    It likes drum and bass though (I don't) (it's a tapper)
    J
    Posted 25th Jul 2013 at 21:10
    allanallen
    It's a gti so I hope it's got gti brakes! Wink
    I'd use the head problem as a good excuse to remove the engine and go through everything.
    Facebook
    Posted 25th Jul 2013 at 21:19
    jimmyrallye
    A weekends work would easily sort all that .. Looks tidy wos it on ebay ?
    Posted 25th Jul 2013 at 21:21
    gjuk
    sorry, GTI6 brakes.
    Posted 25th Jul 2013 at 21:49
    gjuk
    No, it was on retrorides Smile
    Wanted a phase 1 1.9GTI with GTI6 engine. its in VGC under, no rust, other than a bit of surface here and there. Done 60k. have the original bill of sale as well and all MOT's
    Posted 25th Jul 2013 at 21:50
    Those arent semi slicks, theyre crap worn out road tyres LOL
    Posted 25th Jul 2013 at 22:14
    Easy enough bits to tidy upThumbs up
    You can get a banjo fitting for the top of fuel filter so you can fit 10mm fuel pipe direct to railWink
    And the return pipe you run rubber pipe from the rail to the metal pipe coming up the bulkhead from tank.
    What have they done for downpipe clearance?
    Posted 25th Jul 2013 at 22:24
    miles
    Bet the engine's tilted as well, Coils are numbered wrong (number 1 is at the flywheel end) but who numbers coil packs anway, But I have seen this before, DOH
    No Air Filter either
    But the car looks pretty good
    www.pugracing.com
    Posted 25th Jul 2013 at 23:27
    beez_neez_gt
    Just a shame its a phase one with that engine and not original, one day will be worth a bomb having oe engine in.
    Pug fee`ver,
    Pick a Bogey, buy a Pug.
    gjuk
    Thanks
    Posted 26th Jul 2013 at 08:23
    gjuk
    Smile If you say so.
    Posted 26th Jul 2013 at 08:24
    matt evans
    Yokohama Parada Spec 2 if im not mistaken. 100% not or ever will be semi slicks.
    Cheap road tyres at best.Thumbs up
    honestly3k wrote:
    owain wrote:
    Posted 26th Jul 2013 at 09:18
    anth
    Yes definitely paradas
    Posted 26th Jul 2013 at 22:18
    playboyb
    Fair play mate, probably what I will be getting next tbh, always loved 205 gti's and gti6's, put them together and you get this little beast Thumbs up be looking forward to seeing this sorted out will make a lovely little car
    306 1.8 xs moonstone blue-SOLD
    306 gti6 supercharged china blue-SOLD
    406 coupe D9 3.0 V6-SOLD
    Posted 26th Jul 2013 at 22:29
