Author Subject: single wiper conversion
JWP EFi
Turbo Legend!
what model of Citroen ZX uses this? i know you can make a hybrid of 306 and citroen BX bits
Posted 24th Jul 2013 at 20:24
eddy_gti6
Laugh my ass off no hanging around Wink
Posted 24th Jul 2013 at 20:31
JWP EFi
Turbo Legend!
i know of someone who may have one...
Posted 24th Jul 2013 at 20:36
feck off both of you Razz
all zx's have them, as do ax's. quite a faff to make it fit.
Posted 24th Jul 2013 at 21:14
vts_tibi
Nothing special actually. I used a regular BX wiper motor with it's bracket modified. If you are handy with tools you can make it fit. (btw. mine is a Xsara, so the wiper area maybe different from what you have, and I did mine purely for weight saving, and not for aesthetics, but with a bit of OCD you can even make it pretty, eventhough nobody will ever see it under the plastic trim.
VTS
best 60' : 2.272
Team Trackday™
Posted 24th Jul 2013 at 21:29
honestly3k
Why would you bother - it looks s**t on a 306 Meh
Posted 24th Jul 2013 at 21:43
jimmyhackers
i bought a wiper kit which was nie on useless off of ebay. it gave minimal coverage 100 degree arc max. and not a central wiper pivot point. not happy
i ended up chucking a wobbly at them and they sent me a vast array or differnt lenght rotor and wiper arms. the long adjustable linkage they sent was crap (knocked the scuttle panle etc)
i then ended up making my own extended linkage out of two of the original arms cut up, rivited together and bent so it wouldnt rub on anything.
the central mounting point was a c**t, once again i used an original part cut up to hold the pivot point of the wiper centrally. you attach it to the passengers side bolt hole (with the original bolt) and have to cut away the other driver side bolt hole so you can weld/rivit your modded joint housing to it.
you should make sure to attach it securly with a weld/rivit, or youll end up with a wobbly pivot.
i then spent a few hours experimenting and tweaking swapping the various sized arms over and bending the long linkage to perfection, to get the best coverage
then you have to find a larger wiper blade that will cover as much of your windscreen as possible.
you also have to plug your old scuttle pan holes with some bungs and drill/dremmel a new one for your central wiper to poke out of.
i ended up with about a 165-170 degree arc and a fair 75-80% coverage
for extra gayness i also mounted my wiper jets onto my wiper blade.
all in all it looked pretty good, and should do for the time i spent on it
sadly i crashed that car, but i do have the parts i made off of it. if you want i can do a few pics and measurements so you and other people can have a go?
i also plan on fitting it to my new gti eventually (after mot) so i could do my first FAQ worthy article if people are interested?
Posted 25th Jul 2013 at 01:59
jimmyhackers
i found a photo of my handy work
here the link arm and central mounting way i chose (poor welding skills)
and heres teh finsihed article
Posted 25th Jul 2013 at 02:06
blandy
When you have a cage that goes to the suspension turrets there's no room for the original motor
Posted 25th Jul 2013 at 06:22
jimmyhackers
how gay, why are you transporting dangerous animal in a 306 anyways? Smile
Posted 25th Jul 2013 at 14:51
^ that the ex silverstone p1 6?
Posted 25th Jul 2013 at 15:00
jimmyhackers
yes yes it is, alas whats left of she is in bits in boxes in my garage, the rests been recycled into tin cans and hopefuully super cool miniguns or something
Posted 25th Jul 2013 at 15:15
My money was on jimmyhackers making one from a RC car servo so it was wireless to operate from your lap.
  • Posted 25th Jul 2013 at 15:16
    jimmyhackers
    lol a have a few on them lying about, me n my mates used to love rc drift cars.
    theoretical hp per tonne of like 3000bhp
    Posted 26th Jul 2013 at 00:34
    vts_tibi
    A good brushless RC car surprise regular cars up to around 50-60km/h LOL
    VTS
    best 60' : 2.272
    Team Trackday™
    Posted 29th Jul 2013 at 21:35
