Author Subject: How does my engine sound to you?
gjuk
When cold:
View My Video
when warm:
View My Video
When I bought the car I thought it might be a lazy tappet, now having read more in to them I take it a valve is bent?
Posted 22nd Jul 2013 at 18:56
gjuk
and one more when really hot
View My Video
Posted 22nd Jul 2013 at 19:00
ryangti6
Unfortunately that does sound very much like a 'tapper' which is usually a bent valve or guide that has been left in there after a belt failure. Because yours is tapping all the time I'd go with this.
I bought a '6 not so long ago that sounded like a bag of spanners as it had cheap s**t oil in it so I flushed it out and put some decent stuff in there and it sounded lovely. The clue on that car was it was only doing it when warm though but could be worth a try.
Other thing to eliminate are loose spark plugs as they can cause a nasty sounding tap.
Ryan
Posted 22nd Jul 2013 at 19:16
gjuk
Hi
Thanks
All the plugs are right nipped up! Sad
Posted 22nd Jul 2013 at 19:37
I can't view the view the video on my iPhone but I wouldn't worry just yet.
Is it a tick or a tap? Go through some YouTube videos of actual tappers and you'll soon get the jist.
  • Posted 22nd Jul 2013 at 19:41
    gjuk
    more of a tap :-/
    Posted 22nd Jul 2013 at 19:44
    The sewing machine description is actually quite apt.
  • Posted 22nd Jul 2013 at 19:49
    gjuk
    That's not good. So it's head off, replace all the valves, new cambelt, gasket and bolts?
    J
    Posted 22nd Jul 2013 at 20:29
    24seven
    Ideally you'd want to fully recon the head as you can end up with damaged guides and seats as well. Might be easier to just replace the head complete if you can get hold of a known good one.
    Posted 23rd Jul 2013 at 15:05
    if you can do most of the work yourself you will save a lot, damaged seats and valve guides are rare, just replace whichever valve is bent and have the seats checked/cut.
    Posted 23rd Jul 2013 at 15:21
    That is 100% a tapper. Sad
    Exactly this, and it's not that hard to do at all. Smile
    Posted 23rd Jul 2013 at 19:37
    Takedown
    yepz!
    Posted 23rd Jul 2013 at 20:09
    gjuk
    Still, it goes well for the money :-D
    At least as fast as my v70 T5. I'll drive it for a bit and then pull it apart when the weather starts to get s**tty.
    Does anyone on here sell recon good heads?
    J
    Posted 23rd Jul 2013 at 23:41
    Yep, Carl aka 'mechanical_repairs'.
    I think they are £350 inc VAT exchange. Yes
    Posted 24th Jul 2013 at 00:10
    rich306
    I'd also speak to Colin at Pug Performance in Alton Hampshire. He's got quite a few sitting around!!
    Richies Project Rallye
    jamiek_uk2000 wrote:
    - Top Tip!!!
    Posted 24th Jul 2013 at 06:17
    This is true, although the OP lives in Nottingham. Carl is based in Leicester which is a fair bit closer than Alton...
    Posted 24th Jul 2013 at 09:36
    gjuk
    Thanks guys,
    Think I will rip it off and have it checked over by a local guy who does cylinder heads. Cost of valves I read somewhere was around £140 for a full set, should be quite a cheap ish fix after all that.
    J
    Posted 24th Jul 2013 at 11:12
    gjuk
    Oh, the other thing I need to ask, would the car be down on power due to this tapping?
    No, not at all.
    The valves are only 'ever so slighly bent' meaning that the force of the valve springs do ensure they get fully shut. Yes
    However, the "tap" you hear is the valve shutting and "slapping" against the valve seat as it's forced back into place where it doesn't want to go.
    The issue with this is, at some point, the head snaps off the valve and then you've got a knackered engine. There appears to be no correlation with how many miles or how hard the engine is used to when the head will snap off the bent valve. Some people have managed 30 miles, some have managed 30,000 miles. But be assured, that at *some* point the valve will fail. Sad
    Posted 24th Jul 2013 at 13:02
    gjuk
    stan_306gti6 wrote:
    No, not at all.
    Without trying to be pedantic, how can this be the case. Perhaps they shut 99.99% closed but if they are bent, even only slightly there will be a gap, even a very tiny one? Afterall it's metal on Metal with 'no give'. So if It's bent it will not seat properly.
    Interesting that no loss of compression is shown if you do a test on any cylinders.
    Posted 24th Jul 2013 at 18:55
    No loss of compression is shown because the valve shuts. Yes
    Posted 24th Jul 2013 at 22:28
    24seven
    gjuk wrote:
    stan_306gti6 wrote:
    No, not at all.
    The strength of the valve spring is enough to bend the valve shut again, so you don't lose compression. When the valve opens it will return to it's bent shape, when it closes it bends back into the correct shape. Eventually the valve will suffer a fatigue failure and the head of it will drop off and your engine will eat it's own arsehole.
    Posted 25th Jul 2013 at 02:28
    ^^This, as already explained.
    Posted 25th Jul 2013 at 07:46
    gjuk
    Very interesting, thanks for explaining Smile.
    Posted 25th Jul 2013 at 10:32
