Author Subject: Speedo cable for a 205gti with GTI6 engine
gjuk
Hi Smile
Where can I get one of these from please?
My car currently has this (which I think is the speedo cable? But it does not work.
Thank you!!!
Jon
Posted 22nd Jul 2013 at 17:10
As in your other thread - that's a lift up reverse cable which you won't need if you've a 5 speed box fitted.
Speedo cable wise just buy a 205 one and ensure it's kept away from the exhaust manifold. I did this by tucking it behind the downpipe heatshield and then looped a cable tie around an earth stud on the gearbox to pull the cable away.
  • Posted 22nd Jul 2013 at 18:01
    beez_neez_gt
    I did the above and it strained it too much the speedo didnt work, it had to be placed above the mani on a bracket.
    Pug fee`ver,
    Pick a Bogey, buy a Pug.
    Posted 23rd Jul 2013 at 07:56
    Been working fine for me over the last couple of years. Replaced my gearbox recently and attached it the same way again with no hassle what so ever. Was a nice result considering the attachment to the back of the clocks is broken so any excess movement would pull it off.
  • Posted 23rd Jul 2013 at 08:05
    gjuk
    Does anyone have a photo of where this should be in the gearbox please (std 205gti)
    there is a speedo cable connected to the back of the clocks... I can not trace or see quite where it exits from the bulkhead, unless its down low somewhere. The GTI6 engine fills the bay :-/
    Thanks!
    Jon
    Posted 24th Jul 2013 at 18:40
    Nowhere if you dont have a gti6 gearbox.
    Get us a mountain of photos if what your left with and what's a concern and we can help you. Something is to cock somewhere.
    A speedo cable will go from the speedo unit housing by the diff. You can't miss it if you look down the back of the bay or underneath and follow the shafts.
    You cannot miss the speedo cable coming from the bulkhead IMO if it is there. You'll either have a hole because someone has not put a cable in the car or an obvious cable.
  • Posted 24th Jul 2013 at 18:54
    gjuk
    I will take some photos tomorrow. Thank you.
    The car has (what i think is) its standard 205 1.9 gti gearbox.
    Posted 24th Jul 2013 at 22:22
    what year? where is reverse?
    Posted 24th Jul 2013 at 22:26
    gjuk
    its a 1986 D reg, reverse is up and left, lifting the collar up on the gear knob.
    Posted 25th Jul 2013 at 20:05
    that'll be why you have the part pictured then, that's the other end of the lift up collar's cable.
    Posted 25th Jul 2013 at 20:14
    gjuk
    Thanks.
    Not sure where the speedo is meant to go though! hehe
    http://www.306gti6.com/forum/showthread.php?id=156535
    I've just created a thread with some more photos!
    Posted 25th Jul 2013 at 20:31
    allanallen
    This thread is a perfect example of why you should ask questions about 205s on a 205 forum!
    Facebook
    Posted 25th Jul 2013 at 20:48
