Author Subject: GTI6 engine in a 205, some bits not plumbed in, can you help me
gjuk
Could someone advise me what or where these should go on a GTI6 engine please?
The pipe below rungs back under the picture, its about 25 cm long.
las but not least, this is a little leaky.
What is it please, some kind of brake bias auto adjuster?
Thank you!!!
Jon
Posted 22nd Jul 2013 at 17:08
The carbon canister valve - bin it.
The lift up reverse cable you picture - do you have a 6 speed box? If so attach it to the top of the gearbox.
That last pic is a brake compensator valve yes.
  • Posted 22nd Jul 2013 at 17:16
    gjuk
    Looks like my £5 was well spent!
    And the pipe that goes to it, just pull it all off? What does/did it do?
    5 speed box only. at least I think it is anyway.... I've only ever used 5 gears! let me go check
    sweet
    Thanks!
    Posted 22nd Jul 2013 at 17:19
    Remove the carbon canistor pipe and block it off with a bolt or similar.
  • Posted 22nd Jul 2013 at 17:58
    gjuk
    Hi, thanks
    What does the carbon canister do?
    I've checked the gearbox, there is a whole where this screws in to in the top body, but it is only a 5 speed.
    Thanks
    Posted 22nd Jul 2013 at 18:00
    Reduces emmisions apparently.
    The whole left behind, the breather hole? I may have a spare actually.
  • Posted 22nd Jul 2013 at 18:03
    gjuk
    spare bolt for the hole?
    I take it they are some kind of blanking bolt?
    Jon
    Posted 22nd Jul 2013 at 18:27
    Aren't some 5 speeds lift up reverse?Yes
    This cable is what stops you selecting reverse gear when travelling forwards!Wink
    The carbon canister is connected to the fuel tank breather on a 306, it filters fumes from tank, all cat equipped cars have themYes
    So as dan says not needed on your 205Smile
    Posted 22nd Jul 2013 at 18:35
    you'll need that cable if you are using the car's original BE1 gearbox.
    some 205's do have that charcoal canister.
    the pipe is for the idle control valve, you'll need a small filter for that.
    Posted 22nd Jul 2013 at 20:15
    miles
    Looks like all the old wiring's been left behind the 3 pin plug normally does the water temps and oil temp on upto and around 1988 models.
    Brake pipes on most 205's now if not replaced need it, Behind the tank can hide allot
    www.pugracing.com
    Posted 22nd Jul 2013 at 23:24
