Author Subject: A question for anyone with a supercharger set up....
fordygti
I've had my low boost set up installed for about 8 months or more, and it's always losing traction fluid from the canister.
I've changed both inlet and outlet fittings and washers.
When I changed my engine a couple of months back. I happened to turn the canister upside down, and noticed fluid escaping from the screw cap.
This is we're I assume is why the canister is covered in fluid after a drive.
The level is not to full, and the cap is tight.
Anyone else had this problem, or found a way to sort it. It's been doing it for months and just want to get it sorted now.
Thanks.
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 21st Jul 2013 at 18:05
When you say the level is not too full, I take it you have been checking the level whilst the engine is idling as this is the correct procedure. Yes
Posted 21st Jul 2013 at 20:29
fordygti
Sure have, just doesn't seem to seal properly, and have seen other people have the same problem.
Posted 21st Jul 2013 at 20:45
it doesn't seal it's a breather cap.
my smaller charger didn't do this but my c38 does, its really annoying.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 21st Jul 2013 at 21:01
fordygti
That would explain it then. But the level is correct
Posted 21st Jul 2013 at 21:45
If I look up at mine from underneath on a ramp there is always a bit of oil dripping from the pipes and union on the bottom of the filter and reservoir however the level never goes down really so I think it's just a minor weep. There's never any oil on the top though from the cap / breather so I'm not worried about it to be honest. Have half a bottle spare so as long as its not p**sing out Thumbs up.
Posted 21st Jul 2013 at 22:09
pete_rallye
Its probably oil misting in the tank and escaping via the breather. You could try a different breather cap and see if that stops...
Lap of the 'ring
Posted 21st Jul 2013 at 22:17
it's when the fluid froths up and expands.
Posted 21st Jul 2013 at 23:29
pete_rallye
It's oil, it shouldn't really be frothing! That's whats known as cavitation, and its not good!
Lap of the 'ring
Posted 22nd Jul 2013 at 00:28
^^What he said, put a catch tank on the breather perhaps.
Posted 22nd Jul 2013 at 00:36
It doesn't happen with my C38...
Posted 22nd Jul 2013 at 01:12
I think you have to drive it Whistle
Posted 22nd Jul 2013 at 03:02
Drove it to Pugfest and ran up the hill no problems...Whistle
Posted 22nd Jul 2013 at 08:36
rallyestyle
I don't really get any leaks from mine No Only time in the past is when i first installed it and i overfilled it slightly Yes
Just Drive It
Posted 22nd Jul 2013 at 09:21
Mine never leaked a drop, try a cap first.
Posted 22nd Jul 2013 at 09:26
That's what tts told me anyway.
And as for not been good I totally agree
Posted 22nd Jul 2013 at 10:32
I wouldn't waste your time, the issue isn't the cap, it will still do it as its a breather cap, as soon as the oil gets hot and expands it will come out if the overflow.
Have you been topping it up constantly?
maybe it's just overfilled and finds its own level and then you top it up so it does it again and again.
Posted 22nd Jul 2013 at 10:44
pugheaven
IIRC rotrex have changed the fluid levels due to this happening on o few customers set ups, they have a revised dipstick which now has a lower "full" mark on it, go onto the rotrex site (think its a pdf file) and it has a diagram showing the new recommended fluid min and max levels
Posted 22nd Jul 2013 at 16:59
fordygti
It's probs to full then, due to the wrong level calculations.
Thanks guys.
Posted 22nd Jul 2013 at 19:38
