Author Subject: xsi front hub on gti6?
jimmyhackers
my mot report sheet is a lot cleaner now, bar the one fail.
ballljoint excessive play. argh ffs!!!!
this is still there after a new ball joint n swing arm there is still a tiny bit of play. thats from front the hubs ball joint clamp being a bit knackered/worn.
i definately have the right balljoint. but a ive been told i need to replace the hub now :S for cost effectiveness im planning on swapping the one over from my phase 3 xsi onto myphase 1 gti.
will this work/fit?
failing that is ther a quicker /easier bodge anyone can think of? epoxyputy or welding up the lose hole n filing it back or some kind of shim?
any help will be greatly appreciated
cheers
jim
Posted 19th Jul 2013 at 13:33
different size balljoints between p1 and p3..
Posted 19th Jul 2013 at 13:35
jimmyhackers
what if i swap the balljoint over aswell?
Posted 19th Jul 2013 at 13:43
i imagine it'll be ok
Posted 19th Jul 2013 at 13:44
jimmyhackers
loooks like my weekend gone once again then Sad
Posted 19th Jul 2013 at 13:45
you work that slow eh?
Posted 19th Jul 2013 at 13:46
LOL weekend!
Posted 19th Jul 2013 at 13:49
jimmyhackers
two rusty car car with 26 years of rust between them. on a slanted drive. in this heat.
i just imgine horrible things going wrong. a 20 minute job can turn into a complete ballache with a rounded or snapped bolt.
im gonna go at it tommorow and see what happens. if all goes well itll be a few hours instead of my whole weekend.
Posted 20th Jul 2013 at 01:02
jimmyhackers
as predicted.......the job half went ahead.
i dont have a 35mm socket and neither did the six shops i went to, one is ordering me one in for monday
just to check it is definately a 35mm socket i need for the hub nuts? i measured it with my adustable spanner and they came up at 34.5mm so i figure i need a 35mm?
cheers jim
Posted 20th Jul 2013 at 16:04
Use a 36mm impact socket - it's fine. Halfords have them on the shelf.
  • Posted 20th Jul 2013 at 16:23
    jimmyhackers
    ive got one on order from my car parts store but its not here till monday Sad
    35mm bo***cks Sad
    Posted 20th Jul 2013 at 18:53
    If you're desperate - pop to halfords!
  • Posted 20th Jul 2013 at 18:59
    http://www.306gti6.com/forum/showthread.php?id=156300
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 21st Jul 2013 at 21:06
    Yes, the correct size is 35mm, although people have got away with a 36mm before as Dan said.
    Posted 22nd Jul 2013 at 08:39
    jimmyhackers
    thanks for info......
    car spares has p**sed me off now, i ring today when i was told it would be in, no one is working there that was in on friday and no one knows jack about my socket.
    i ring the nechells store who supposedly have the socket and they dont, they have to order it in.
    so ebay once again will be saving my day.
    Posted 22nd Jul 2013 at 12:52
    Just get a 36mm, works perfect and will come in handy for any other applications you need it for rather than the 35mm
    Posted 22nd Jul 2013 at 13:11
    I've used the 36 on umpteen hubnuts with no wear to the nuts and won't be buying a 35 as the 36 does the job perfectly. Won't even slip on the tightest of nuts.
  • Posted 22nd Jul 2013 at 13:25
    +1 ^
    the 36mm is also a perfect fit on a mk3 Deisel mondeo oil filter housing.
    Posted 22nd Jul 2013 at 13:50
