Author Subject: race head/fast road
bengti6
Here goes again, after a bit of a clean up and a sort out i have a new ad. gti6 head which has piper 285 cams fitted can just see in one of the photos. Has also been ported and polished to a high standard, i believed this head may have originally done by longmans but i have been informed it may have been done by brett sims who used to work for longmans as he put a four digit number on the heads, this one has 8505 as in pic. I cant tell if it has been skimmed/faced although head is flat so may have been done in the past. I haven't used this head as have had a change of plan so its just as i brought it. I did advertise this head recently and there was a few comments that it was sat on the valves in pics, this was not the case and was people just assuming (wrongly). Serious enquiries only please, and please don't fill this post up with useless spam/comments. £450
205 gti6 1989
Posted 17th Jul 2013 at 20:14
ashbash
I'm seeing brett this week so will find out for you if this is one that he has done.
Posted 17th Jul 2013 at 23:45
24seven
Much better mate. Smile Good luck with the sale!
Posted 18th Jul 2013 at 00:32
bengti6
Cheers lads
205 gti6 1989
Posted 18th Jul 2013 at 18:06
pete_rallye
Interested in splitting? Would like the head but not fussed about cams, buckets, valves or springs.
Lap of the 'ring
Posted 18th Jul 2013 at 22:11
bengti6
Will only sell complete thanks Pete.
205 gti6 1989
Posted 18th Jul 2013 at 23:20
bengti6
Bump
205 gti6 1989
Posted 20th Jul 2013 at 21:10
alexcrosse
why did it need 2 new inlet valves and a clean up in chamber 2? Any confirmation of this being a simms head yet?
Posted 22nd Jul 2013 at 09:40
pete_rallye
I can confirm 99% that this is a Longmans head. The porting is identical to the ones I have had, and the 4 digit number is located in exactly the same place as Longmans used to put theirs. Whether Brett Sims did the porting for Longmans or not I'm not sure...
Lap of the 'ring
Posted 22nd Jul 2013 at 10:06
he didnt, he did the cast iron heads so I heard Wink
that's not to say he didnt know what they looked like though.
Posted 22nd Jul 2013 at 10:37
pete_rallye
If anyone is interested in just the cams, buckets and springs let me know as I'd buy this if I have a buyer for the bits I don't want...
Lap of the 'ring
Posted 22nd Jul 2013 at 15:18
bengti6
Thanks Pete for confirming the head as a longmans. This would make a reasonably priced head if you wanted to pass cams on. I think it's priced quite well for what's been done
205 gti6 1989
Posted 22nd Jul 2013 at 23:10
andywillis89
Is this head/cams a direct bolt on or is other internal work required for the bottom end? Thanks
Posted 25th Jul 2013 at 15:00
pete_rallye
Likely to need pocketed pistons unfortunately. I ran 285h's a while back and ended up with a rod through the block due to their not been enough valve>piston clearance. That head looks like it has been quite heavily skimmed also so clearance will be even more of an issue. You can have the standard pistons pocketed, or buy aftermarket pistons.
Lap of the 'ring
Posted 25th Jul 2013 at 22:00
bengti6
Bump
205 gti6 1989
Posted 26th Jul 2013 at 18:45
bengti6
Serious offers are invited
205 gti6 1989
Posted 27th Jul 2013 at 08:50
bengti6
Sold
205 gti6 1989
Posted 31st Jul 2013 at 23:05
