Author Subject: Would these fit?
drewhughes
4 stud 7jx15-ch
15"
Posted 16th Jul 2013 at 19:27
depends on offset and pcd.
Posted 16th Jul 2013 at 19:35
What PCD and offset?
  • Posted 16th Jul 2013 at 19:35
    drewhughes
    Posted 16th Jul 2013 at 19:37
    renfault = nono
    they are 4x100.
    Posted 16th Jul 2013 at 19:39
    drewhughes
    so whats the full size I need then for a straight fit on the 306 if im running r888's
    ET, Offset, PCD etc
    Just so I dont have to keep posting on here every time some come up on ebay haha
    Posted 16th Jul 2013 at 19:42
    burnout21
    4 x 108 is what you need. You can use spacers for different offsets etc.
    Think most Ford's fit. But someone will correct me if need be.
    Posted 16th Jul 2013 at 20:01
    For reference, the ET** stamp is the offset.
  • Posted 16th Jul 2013 at 20:02
    ET15 is ideal for a 7 inch wide rimThumbs up
    Posted 16th Jul 2013 at 20:18
    birk
    195/50/15 tyre, r888 are pretty chunky.
    Dimma + Gt35 turbo = Ninja
    Solid rear beam mounts £130
    07889376885
    Dan
    Posted 16th Jul 2013 at 20:49
    drewhughes
    how bout these?
    Ford fitment 4x108 pcd. Offset is i believe ET35/38
    Posted 28th Jul 2013 at 18:52
    no, pug needs ET 19 on a 6" rim, 15 or less for 7".
    Posted 28th Jul 2013 at 19:04
    mik
    Also need to look at centre bore and get a spigot ring to fit if necessary as it is essential for safety reasons that the wheel centre bore fits correctly on the hub. The bolts only do part of the work. IIRC Ford fitment wheels do not have the same centre bore size as Peugeot - someone else on here will know the exact sizes.
    Cherry Rallye SOLD
    Posted 28th Jul 2013 at 19:36
    they're smaller, so a spigot would be a fat lot of good LOL
    you'd need ford to pug spacers, which weigh a ton and cost a lot.
    Posted 28th Jul 2013 at 19:41
    mik
    ...or get them reamed out to appropriate bore by someone who knows what they are doing if other dimensions were right?
    Cherry Rallye SOLD
    Posted 28th Jul 2013 at 19:48
